{"name":"Altair Events","description":"Altair Events","url":"https:\/\/events.altair.com","home":"https:\/\/events.altair.com\/pt-br\/","gmt_offset":-4,"timezone_string":"America\/Detroit","namespaces":["oembed\/1.0","wpml\/v1","post-smtp\/v1","post-smtp\/v2","psd\/v1","redirection\/v1","yoast\/v1","wpml\/st\/v1","wpml\/tm\/v1","wpml\/ate\/v1","otgs\/installer\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/events.altair.com\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"O URL do recurso de onde devem ser coletados os dados do oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"O URL do recurso de onde devem ser coletados os dados do oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"O formato oEmbed a ser usado.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"A largura m\u00e1xima, em p\u00edxeis, do frame da m\u00eddia incorporada.","type":"integer","default":600,"required":false},"maxheight":{"description":"A altura m\u00e1xima, em p\u00edxeis, do frame da m\u00eddia incorporada.","type":"integer","required":false},"discover":{"description":"Fazer ou n\u00e3o uma requisi\u00e7\u00e3o de descoberta para um servidor oEmbed n\u00e3o pertencente \u00e0 lista de servidores permitidos.","type":"boolean","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/oembed\/1.0\/proxy"}]}},"\/wpml\/v1":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1"}]}},"\/wpml\/v1\/custom-xml-config":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/custom-xml-config"}]}},"\/wpml\/v1\/custom-xml-config\/validate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/custom-xml-config\/validate"}]}},"\/post-smtp\/v1":{"namespace":"post-smtp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"post-smtp\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/post-smtp\/v1"}]}},"\/post-smtp\/v1\/connect-app":{"namespace":"post-smtp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/post-smtp\/v1\/connect-app"}]}},"\/post-smtp\/v1\/get-logs":{"namespace":"post-smtp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/post-smtp\/v1\/get-logs"}]}},"\/post-smtp\/v1\/disconnect-site":{"namespace":"post-smtp\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/post-smtp\/v1\/disconnect-site"}]}},"\/post-smtp\/v1\/get-log":{"namespace":"post-smtp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/post-smtp\/v1\/get-log"}]}},"\/post-smtp\/v1\/resend-email":{"namespace":"post-smtp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/post-smtp\/v1\/resend-email"}]}},"\/post-smtp\/v2":{"namespace":"post-smtp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"post-smtp\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/post-smtp\/v2"}]}},"\/post-smtp\/v2\/get-logs":{"namespace":"post-smtp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/post-smtp\/v2\/get-logs"}]}},"\/post-smtp\/v2\/validate-license":{"namespace":"post-smtp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/post-smtp\/v2\/validate-license"}]}},"\/psd\/v1":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"psd\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/psd\/v1"}]}},"\/psd\/v1\/get-logs":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/psd\/v1\/get-logs"}]}},"\/psd\/v1\/get-details":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/psd\/v1\/get-details"}]}},"\/psd\/v1\/resend-email":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/psd\/v1\/resend-email"}]}},"\/psd\/v1\/email-count":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/psd\/v1\/email-count"}]}},"\/psd\/v1\/minimize-maximize-ad":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/psd\/v1\/minimize-maximize-ad"}]}},"\/psd\/v1\/get-failed-logs":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/psd\/v1\/get-failed-logs"}]}},"\/psd\/v1\/open-notification":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/psd\/v1\/open-notification"}]}},"\/psd\/v1\/remove-notification":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/psd\/v1\/remove-notification"}]}},"\/redirection\/v1":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"redirection\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1"}]}},"\/redirection\/v1\/redirect":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1\/redirect"}]}},"\/redirection\/v1\/redirect\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/redirect\/post":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"text":{"description":"Text to match","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1\/redirect\/post"}]}},"\/redirection\/v1\/bulk\/redirect\/(?P<bulk>delete|enable|disable|reset)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"global":{"description":"Apply bulk action globally, as per filters","type":"boolean","required":false},"items":{"description":"Array of IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/group":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true},"status":{"description":"Status of the group","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1\/group"}]}},"\/redirection\/v1\/group\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true},"status":{"description":"Status of the group","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/bulk\/group\/(?P<bulk>delete|enable|disable)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/log":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1\/log"}]}},"\/redirection\/v1\/bulk\/log\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/404":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1\/404"}]}},"\/redirection\/v1\/bulk\/404\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/setting":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1\/setting"}]}},"\/redirection\/v1\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Name","type":"string","required":false},"value":{"description":"Value","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1\/plugin"}]}},"\/redirection\/v1\/plugin\/delete":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1\/plugin\/delete"}]}},"\/redirection\/v1\/plugin\/test":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1\/plugin\/test"}]}},"\/redirection\/v1\/plugin\/data":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"upgrade":{"description":"Upgrade parameter","type":"string","enum":["stop","skip","retry"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1\/plugin\/data"}]}},"\/redirection\/v1\/import\/file\/(?P<group_id>\\d+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/import\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/redirection\/v1\/import\/plugin"}]}},"\/redirection\/v1\/export\/(?P<module>1|2|3|all)\/(?P<format>csv|apache|nginx|json)":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/wincher\/authorization-url":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/wincher\/authorization-url"}]}},"\/yoast\/v1\/wincher\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true},"websiteId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/wincher\/authenticate"}]}},"\/yoast\/v1\/wincher\/keyphrases\/track":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/wincher\/keyphrases\/track"}]}},"\/yoast\/v1\/wincher\/keyphrases":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":false},"permalink":{"required":false},"startAt":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/wincher\/keyphrases"}]}},"\/yoast\/v1\/wincher\/keyphrases\/untrack":{"namespace":"yoast\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/wincher\/keyphrases\/untrack"}]}},"\/yoast\/v1\/wincher\/account\/limit":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/wincher\/account\/limit"}]}},"\/yoast\/v1\/wincher\/account\/upgrade-campaign":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/wincher\/account\/upgrade-campaign"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/yoast\/v1\/workouts"}]}},"\/wpml\/st\/v1":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/st\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/st\/v1"}]}},"\/wpml\/st\/v1\/strings\/settings":{"namespace":"wpml\/st\/v1","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"autoregisterType":{"type":"integer","default":0,"required":false},"shouldRegisterBackendStrings":{"type":"integer","default":0,"required":false},"setNoticeThatCachePluginCanBlockAutoregisterAsDismissed":{"type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/st\/v1\/strings\/settings"}]}},"\/wpml\/st\/v1\/strings\/itemscount":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/st\/v1\/strings\/itemscount"}]}},"\/wpml\/st\/v1\/strings":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/st\/v1\/strings"}]}},"\/wpml\/st\/v1\/strings\/filters":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/st\/v1\/strings\/filters"}]}},"\/wpml\/st\/v1\/string-packages":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/st\/v1\/string-packages"}]}},"\/wpml\/st\/v1\/strings\/processstringsqueue":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/st\/v1\/strings\/processstringsqueue"}]}},"\/wpml\/tm\/v1":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/tm\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/store":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_job_id":{"type":"string","required":true},"ate_job_data":{"type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/store"}]}},"\/wpml\/tm\/v1\/xliff\/fetch\/(?P<jobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/ams\/register_manager":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/register_manager"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/translators":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/translators"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/managers":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/managers"}]}},"\/wpml\/tm\/v1\/ams\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/status"}]}},"\/wpml\/tm\/v1\/ams\/console":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/console"}]}},"\/wpml\/tm\/v1\/ams\/engines":{"namespace":"wpml\/tm\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ams\/engines"}]}},"\/wpml\/tm\/v1\/ate\/jobs":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ate\/jobs"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/jobs":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"local_job_ids":{"type":"string","required":false},"scope":{"type":"string","required":false},"id":{"type":"integer","required":false},"title":{"type":"string","required":false},"source_language":{"type":"string","required":false},"target_language":{"type":"string","required":false},"status":{"type":"string","required":false},"needs_update":{"type":"string","required":false},"limit":{"type":"integer","required":false},"offset":{"type":"integer","required":false},"sorting":{"required":false},"translated_by":{"type":"string","required":false},"sent_from":{"type":"string","required":false},"sent_to":{"type":"string","required":false},"deadline_from":{"type":"string","required":false},"deadline_to":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/jobs"}]}},"\/wpml\/tm\/v1\/jobs\/assign":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"jobId":{"required":true},"type":{"required":false},"translatorId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/jobs\/assign"}]}},"\/wpml\/tm\/v1\/jobs\/cancel":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/jobs\/cancel"}]}},"\/wpml\/tm\/v1\/tp\/xliff\/download\/(?P<job_id>\\d+)\/(?P<job_type>\\w+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"job_id":{"required":true},"job_type":{"required":true},"json":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/tp\/apply-translations":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/tp\/apply-translations"}]}},"\/wpml\/tm\/v1\/tp\/batches\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batchId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/tp\/batches\/sync"}]}},"\/wpml\/tm\/v1\/tp\/batches\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/tp\/batches\/status"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"lockKey":{"type":"string","required":false},"ateToken":{"type":"string","required":false},"page":{"type":"int","required":false},"numberOfPages":{"type":"int","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/sync"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/download":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/download"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/retry":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/retry"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/receive\/(?P<wpmlJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpmlJobId":{"type":"int","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)\/fix":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wpml\/ate\/v1":{"namespace":"wpml\/ate\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/ate\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/ate\/v1"}]}},"\/wpml\/ate\/v1\/ate\/proxy":{"namespace":"wpml\/ate\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/ate\/v1\/ate\/proxy"}]}},"\/wpml\/st\/v1\/import_mo_strings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"type":"array","required":false},"themes":{"type":"array","required":false},"other":{"type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/st\/v1\/import_mo_strings"}]}},"\/wpml\/st\/v1\/pre_generate_mo_files":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/st\/v1\/pre_generate_mo_files"}]}},"\/wpml\/st\/v1\/settings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"group":{"required":true},"key":{"required":true},"data":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/st\/v1\/settings"}]}},"\/wpml\/v1\/updates":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/updates"}]}},"\/wpml\/v1\/item-sections\/populated":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/item-sections\/populated"}]}},"\/wpml\/v1\/posts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/posts"}]}},"\/wpml\/v1\/posts\/count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/posts\/count"}]}},"\/wpml\/v1\/send-to-translation\/validate-translation-options":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/send-to-translation\/validate-translation-options"}]}},"\/wpml\/v1\/send-to-translation\/default-batch-name":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/send-to-translation\/default-batch-name"}]}},"\/wpml\/v1\/send-to-translation\/validate-batch-name":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/send-to-translation\/validate-batch-name"}]}},"\/wpml\/v1\/set-review-translation-option":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/set-review-translation-option"}]}},"\/wpml\/v1\/posts\/hierarchical":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/posts\/hierarchical"}]}},"\/wpml\/v1\/posts\/taxonomies":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/posts\/taxonomies"}]}},"\/wpml\/v1\/posts\/terms":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/posts\/terms"}]}},"\/wpml\/v1\/translate-everything\/enable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/translate-everything\/enable"}]}},"\/wpml\/v1\/translate-everything\/disable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/translate-everything\/disable"}]}},"\/wpml\/v1\/getuntranslatedtypescount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/getuntranslatedtypescount"}]}},"\/wpml\/v1\/save-translator-note":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/save-translator-note"}]}},"\/wpml\/v1\/credits":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/credits"}]}},"\/wpml\/v1\/translation-proxy\/commit-batch":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/translation-proxy\/commit-batch"}]}},"\/wpml\/v1\/tranlsation-proxy\/getlastpickedup":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/tranlsation-proxy\/getlastpickedup"}]}},"\/wpml\/v1\/translation-proxy\/getRemoteJobsCount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/translation-proxy\/getRemoteJobsCount"}]}},"\/wpml\/v1\/gettranslationstatus":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/gettranslationstatus"}]}},"\/wpml\/v1\/getlocaltranslatorbyid":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/getlocaltranslatorbyid"}]}},"\/wpml\/v1\/reloadremotetranslationservice":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/reloadremotetranslationservice"}]}},"\/wpml\/v1\/gettranslationeditortype":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/gettranslationeditortype"}]}},"\/wpml\/v1\/translate-existing-content":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/translate-existing-content"}]}},"\/wpml\/v1\/get-needs-update-count-created-in-cte":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/get-needs-update-count-created-in-cte"}]}},"\/wpml\/v1\/get-engines":{"namespace":"wpml\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/get-engines"}]}},"\/wpml\/v1\/save-automatic-translation-settings":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/save-automatic-translation-settings"}]}},"\/wpml\/v1\/getlocaltranslators":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/getlocaltranslators"}]}},"\/wpml\/v1\/account-balances":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/account-balances"}]}},"\/wpml\/v1\/glossary-count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/glossary-count"}]}},"\/wpml\/v1\/enable-ate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/enable-ate"}]}},"\/wpml\/v1\/get-dismissed-notices":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/get-dismissed-notices"}]}},"\/wpml\/v1\/dismiss-notice":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/dismiss-notice"}]}},"\/wpml\/v1\/dismiss-notice-per-user":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wpml\/v1\/dismiss-notice-per-user"}]}},"\/otgs\/installer\/v1":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"otgs\/installer\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/otgs\/installer\/v1"}]}},"\/otgs\/installer\/v1\/push\/fetch-subscription":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/otgs\/installer\/v1\/push\/fetch-subscription"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limitar resultados com base no relacionamento entre m\u00faltiplas taxonomias.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilidade de incluir termos descendentes nos termos limitando o conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilidade de incluir termos descendentes nos termos limitando o conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limitar resultados de itens que sejam fixos.","type":"boolean","required":false},"format":{"description":"Limita conjunto de resultados a itens atribu\u00eddos a um ou mais formatos espec\u00edficos.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"O formato para o post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Se o post deve ser tratado como fixo.","type":"boolean","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"categories":{"description":"Os termos atribu\u00eddos ao post na taxonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Substitui o tamanho padr\u00e3o do resumo.","type":"integer","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"O formato para o post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Se o post deve ser tratado como fixo.","type":"boolean","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"categories":{"description":"Os termos atribu\u00eddos ao post na taxonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"O formato para o post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Se o post deve ser tratado como fixo.","type":"boolean","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"categories":{"description":"Os termos atribu\u00eddos ao post na taxonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limitar resultados para posts com um valor menu_order espec\u00edfico.","type":"integer","required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limitar resultados para itens cujos ascendentes t\u00eam determinados IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar resultados para todos os itens, exceto aqueles de um ID de ascendente em particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A ordem do post em rela\u00e7\u00e3o a outros posts.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Substitui o tamanho padr\u00e3o do resumo.","type":"integer","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A ordem do post em rela\u00e7\u00e3o a outros posts.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A ordem do post em rela\u00e7\u00e3o a outros posts.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limitar resultados para itens cujos ascendentes t\u00eam determinados IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar resultados para todos os itens, exceto aqueles de um ID de ascendente em particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limitar resultados a anexos de um tipo de m\u00eddia em particular.","type":"string","enum":["image","video","text","application","audio"],"required":false},"mime_type":{"default":null,"description":"Limitar resultados a anexos de um tipo MIME em particular.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"alt_text":{"description":"Texto alternativo para exibir quando o anexo n\u00e3o \u00e9 exibido.","type":"string","required":false},"caption":{"description":"A legenda do anexo.","type":"object","properties":{"raw":{"description":"Legenda para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Legenda HTML para o anexo, transformada para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"A descri\u00e7\u00e3o do anexo.","type":"object","properties":{"raw":{"description":"Descri\u00e7\u00e3o para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Descri\u00e7\u00e3o HTML para o anexo, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"O ID para o post associado ao anexo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"alt_text":{"description":"Texto alternativo para exibir quando o anexo n\u00e3o \u00e9 exibido.","type":"string","required":false},"caption":{"description":"A legenda do anexo.","type":"object","properties":{"raw":{"description":"Legenda para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Legenda HTML para o anexo, transformada para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"A descri\u00e7\u00e3o do anexo.","type":"object","properties":{"raw":{"description":"Descri\u00e7\u00e3o para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Descri\u00e7\u00e3o HTML para o anexo, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"O ID para o post associado ao anexo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico para o anexo.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL para o arquivo de imagem editado.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array de edi\u00e7\u00f5es da imagem.","type":"array","minItems":1,"items":{"description":"Edi\u00e7\u00e3o de imagem.","type":"object","required":["type","args"],"oneOf":[{"title":"Rota\u00e7\u00e3o","properties":{"type":{"description":"Tipo de rota\u00e7\u00e3o.","type":"string","enum":["rotate"]},"args":{"description":"Argumentos para rota\u00e7\u00e3o.","type":"object","required":["angle"],"properties":{"angle":{"description":"\u00c2ngulo para girar no sentido hor\u00e1rio em graus..","type":"number"}}}}},{"title":"Recortar","properties":{"type":{"description":"Tipo de recorte.","type":"string","enum":["crop"]},"args":{"description":"Argumentos para recortar.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Posi\u00e7\u00e3o vertical da esquerda para iniciar um recorte como uma porcentagem da largura da imagem.","type":"number"},"top":{"description":"Posi\u00e7\u00e3o vertical do topo para iniciar um recorte como uma porcentagem da altura da imagem.","type":"number"},"width":{"description":"Largura para recortar como uma porcentagem da largura da imagem.","type":"number"},"height":{"description":"Altura para recortar como uma porcentagem da altura da imagem.","type":"number"}}}}}]},"required":false},"rotation":{"description":"A quantidade para girar a imagem no sentido hor\u00e1rio em graus. Obsoleto: use `modifiers` no lugar.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Como uma porcentagem da imagem, a posi\u00e7\u00e3o x para iniciar o recorte. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Como uma porcentagem da imagem, a posi\u00e7\u00e3o y para iniciar o recorte. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Como uma porcentagem da imagem, a largura que a imagem ser\u00e1 recortada. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Como uma porcentagem da imagem, a altura que a imagem ser\u00e1 recortada. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limitar resultados com base no relacionamento entre m\u00faltiplas taxonomias.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limitar resultados para posts com um valor menu_order espec\u00edfico.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"O t\u00edtulo para o objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para o objeto, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o objeto em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"A fam\u00edlia de objetos originalmente representados, como \"post_type\" ou \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Um nome de status para o objeto.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"parent":{"default":0,"description":"O ID do item ascendente ao objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto referente ao atributo de t\u00edtulo do elemento de link deste item de menu.","type":"string","required":false},"classes":{"description":"Nomes de classe do elemento de link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"A descri\u00e7\u00e3o deste item de menu.","type":"string","required":false},"menu_order":{"default":1,"description":"O ID de banco de dados do nav_menu_item ascendente deste item, se houver. Caso contr\u00e1rio, \u00e9 0.","type":"integer","minimum":1,"required":false},"object":{"description":"O tipo do objeto originalmente representado, como \"category,\" \"post\" ou \"attachment\".","type":"string","required":false},"object_id":{"default":0,"description":"O ID no banco de dados do objeto original que representa este item de menu, por exemplo o ID para os posts e o term_id para as categorias.","type":"integer","minimum":0,"required":false},"target":{"description":"O atributo target (destino) de um elemento de link para este item de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"O URL para o qual este item de menu aponta.","type":"string","format":"uri","required":false},"xfn":{"description":"A rela\u00e7\u00e3o XFN expressa no link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Os termos atribu\u00eddos ao objeto na taxonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para o objeto, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o objeto em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"A fam\u00edlia de objetos originalmente representados, como \"post_type\" ou \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Um nome de status para o objeto.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"parent":{"description":"O ID do item ascendente ao objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto referente ao atributo de t\u00edtulo do elemento de link deste item de menu.","type":"string","required":false},"classes":{"description":"Nomes de classe do elemento de link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"A descri\u00e7\u00e3o deste item de menu.","type":"string","required":false},"menu_order":{"description":"O ID de banco de dados do nav_menu_item ascendente deste item, se houver. Caso contr\u00e1rio, \u00e9 0.","type":"integer","minimum":1,"required":false},"object":{"description":"O tipo do objeto originalmente representado, como \"category,\" \"post\" ou \"attachment\".","type":"string","required":false},"object_id":{"description":"O ID no banco de dados do objeto original que representa este item de menu, por exemplo o ID para os posts e o term_id para as categorias.","type":"integer","minimum":0,"required":false},"target":{"description":"O atributo target (destino) de um elemento de link para este item de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"O URL para o qual este item de menu aponta.","type":"string","format":"uri","required":false},"xfn":{"description":"A rela\u00e7\u00e3o XFN expressa no link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Os termos atribu\u00eddos ao objeto na taxonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao objeto.","type":"integer","minimum":0,"required":false},"title":{"description":"O t\u00edtulo para o objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para o objeto, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o objeto em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"A fam\u00edlia de objetos originalmente representados, como \"post_type\" ou \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Um nome de status para o objeto.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"attr_title":{"description":"Texto referente ao atributo de t\u00edtulo do elemento de link deste item de menu.","type":"string","required":false},"classes":{"description":"Nomes de classe do elemento de link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"A descri\u00e7\u00e3o deste item de menu.","type":"string","required":false},"menu_order":{"description":"O ID de banco de dados do nav_menu_item ascendente deste item, se houver. Caso contr\u00e1rio, \u00e9 0.","type":"integer","minimum":1,"required":false},"object":{"description":"O tipo do objeto originalmente representado, como \"category,\" \"post\" ou \"attachment\".","type":"string","required":false},"object_id":{"description":"O ID no banco de dados do objeto original que representa este item de menu, por exemplo o ID para os posts e o term_id para as categorias.","type":"integer","minimum":0,"required":false},"target":{"description":"O atributo target (destino) de um elemento de link para este item de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"O URL para o qual este item de menu aponta.","type":"string","format":"uri","required":false},"xfn":{"description":"A rela\u00e7\u00e3o XFN expressa no link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Os termos atribu\u00eddos ao objeto na taxonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limitar resultados com base no relacionamento entre m\u00faltiplas taxonomias.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wp_pattern_category":{"description":"Os termos atribu\u00eddos ao post na taxonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Substitui o tamanho padr\u00e3o do resumo.","type":"integer","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wp_pattern_category":{"description":"Os termos atribu\u00eddos ao post na taxonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wp_pattern_category":{"description":"Os termos atribu\u00eddos ao post na taxonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar ao ID do post especificado.","type":"integer","required":false},"area":{"description":"Limitar \u00e0 \u00e1rea de parte de modelo especificada.","type":"string","required":false},"post_type":{"description":"Tipo de post para obter os modelos.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"default":"","description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"default":"publish","description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"O slug do modelo para obter o padr\u00e3o para","type":"string","required":true},"is_custom":{"description":"Indica se um modelo \u00e9 personalizado ou faz parte da hierarquia de modelo","type":"boolean","required":false},"template_prefix":{"description":"O prefixo do modelo para o modelo criado. Isso \u00e9 usado para extrair o tipo de modelo principal, por exemplo, em `taxonomia-livros` extrai a `taxonomia`","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"area":{"description":"Onde a parte do modelo se destina a uso (cabe\u00e7alho, rodap\u00e9 etc.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar ao ID do post especificado.","type":"integer","required":false},"area":{"description":"Limitar \u00e0 \u00e1rea de parte de modelo especificada.","type":"string","required":false},"post_type":{"description":"Tipo de post para obter os modelos.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"default":"","description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"default":"publish","description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"area":{"description":"Onde a parte do modelo se destina a uso (cabe\u00e7alho, rodap\u00e9 etc.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"O slug do modelo para obter o padr\u00e3o para","type":"string","required":true},"is_custom":{"description":"Indica se um modelo \u00e9 personalizado ou faz parte da hierarquia de modelo","type":"boolean","required":false},"template_prefix":{"description":"O prefixo do modelo para o modelo criado. Isso \u00e9 usado para extrair o tipo de modelo principal, por exemplo, em `taxonomia-livros` extrai a `taxonomia`","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"area":{"description":"Onde a parte do modelo se destina a uso (cabe\u00e7alho, rodap\u00e9 etc.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID ascendente da revis\u00e3o de estilos globais.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para a revis\u00e3o de estilos globais.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"O identificador do tema","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"O identificador do tema","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Estilos globais.","type":["object"],"required":false},"settings":{"description":"Configura\u00e7\u00f5es globais","type":["object"],"required":false},"title":{"description":"T\u00edtulo da varia\u00e7\u00e3o de estilos globais.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para a varia\u00e7\u00e3o de estilos globais, como no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Vers\u00e3o do schema do theme.json utilizado para as configura\u00e7\u00f5es de tipografia.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"declara\u00e7\u00e3o font-family no formato para o theme.json, codificado como uma string.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"theme_json_version":{"description":"Vers\u00e3o do schema do theme.json utilizado para as configura\u00e7\u00f5es de tipografia.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"declara\u00e7\u00e3o font-family no formato para o theme.json, codificado como uma string.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"id","enum":["id","include"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"theme_json_version":{"description":"Vers\u00e3o do schema do theme.json utilizado para as configura\u00e7\u00f5es de tipografia.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"declara\u00e7\u00e3o font-face no formato para o theme.json, codificado como uma string.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para o tipo de fonte.","type":"integer","required":true},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para o tipo de fonte.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/event":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limitar resultados para itens cujos ascendentes t\u00eam determinados IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar resultados para todos os itens, exceto aqueles de um ID de ascendente em particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/event"}]}},"\/wp\/v2\/event\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/event\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/event\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Um identificador alfanum\u00e9rico para o tipo de post.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Um identificador alfanum\u00e9rico para o status.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Limitar resultados para taxonomias associadas com um tipo especifico de post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Um identificador alfanum\u00e9rico para a taxonomia.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar resultados de termos atribu\u00eddos a um ascendente espec\u00edfico.","type":"integer","required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"parent":{"description":"ID do termo ascendente.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"parent":{"description":"ID do termo ascendente.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"locations":{"description":"As localiza\u00e7\u00f5es atribu\u00eddas ao menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Se as p\u00e1ginas de n\u00edvel superior ser\u00e3o adicionadas automaticamente a este menu ou n\u00e3o.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"locations":{"description":"As localiza\u00e7\u00f5es atribu\u00eddas ao menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Se as p\u00e1ginas de n\u00edvel superior ser\u00e3o adicionadas automaticamente a este menu ou n\u00e3o.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"default":"asc","description":"Ordenar atributos de forma ascendente ou descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Ordenar cole\u00e7\u00e3o por atributo do usu\u00e1rio.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limitar resultados a usu\u00e1rios com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limitar resultados a usu\u00e1rios que tenham pelo menos uma dada fun\u00e7\u00e3o espec\u00edfica. Aceita lista separada por v\u00edrgulas ou uma fun\u00e7\u00e3o apenas.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limitar resultados a usu\u00e1rios que tenham pelo menos uma dada capacidade espec\u00edfica. Aceita lista separada por v\u00edrgulas ou uma capacidade apenas.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limitar resultados a usu\u00e1rios considerados autores.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limitar resultados para usu\u00e1rios que publicaram posts.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","event":"event"}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Nome de login para o usu\u00e1rio.","type":"string","required":true},"name":{"description":"Nome de exibi\u00e7\u00e3o para o usu\u00e1rio.","type":"string","required":false},"first_name":{"description":"Nome para o usu\u00e1rio.","type":"string","required":false},"last_name":{"description":"Sobrenome para o usu\u00e1rio.","type":"string","required":false},"email":{"description":"O endere\u00e7o de e-mail para o usu\u00e1rio.","type":"string","format":"email","required":true},"url":{"description":"URL do usu\u00e1rio.","type":"string","format":"uri","required":false},"description":{"description":"Descri\u00e7\u00e3o do usu\u00e1rio.","type":"string","required":false},"locale":{"description":"Localidade para o usu\u00e1rio.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","ja","ko_KR","pt_BR","th","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"O apelido para o usu\u00e1rio.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o usu\u00e1rio.","type":"string","required":false},"roles":{"description":"Fun\u00e7\u00f5es atribu\u00eddas ao usu\u00e1rio.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Senha para o usu\u00e1rio (nunca incluso).","type":"string","required":true},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A data e o hor\u00e1rio que as prefer\u00eancias foram atualizadas.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o usu\u00e1rio.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o usu\u00e1rio.","type":"integer","required":false},"username":{"description":"Nome de login para o usu\u00e1rio.","type":"string","required":false},"name":{"description":"Nome de exibi\u00e7\u00e3o para o usu\u00e1rio.","type":"string","required":false},"first_name":{"description":"Nome para o usu\u00e1rio.","type":"string","required":false},"last_name":{"description":"Sobrenome para o usu\u00e1rio.","type":"string","required":false},"email":{"description":"O endere\u00e7o de e-mail para o usu\u00e1rio.","type":"string","format":"email","required":false},"url":{"description":"URL do usu\u00e1rio.","type":"string","format":"uri","required":false},"description":{"description":"Descri\u00e7\u00e3o do usu\u00e1rio.","type":"string","required":false},"locale":{"description":"Localidade para o usu\u00e1rio.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","ja","ko_KR","pt_BR","th","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"O apelido para o usu\u00e1rio.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o usu\u00e1rio.","type":"string","required":false},"roles":{"description":"Fun\u00e7\u00f5es atribu\u00eddas ao usu\u00e1rio.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Senha para o usu\u00e1rio (nunca incluso).","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A data e o hor\u00e1rio que as prefer\u00eancias foram atualizadas.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o usu\u00e1rio.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio para ser verdadeiro, como usu\u00e1rios n\u00e3o suporta lixeira.","required":false},"reassign":{"type":"integer","description":"Reatribuir os posts e links do usu\u00e1rio exclu\u00eddo para este ID de usu\u00e1rio.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Nome de login para o usu\u00e1rio.","type":"string","required":false},"name":{"description":"Nome de exibi\u00e7\u00e3o para o usu\u00e1rio.","type":"string","required":false},"first_name":{"description":"Nome para o usu\u00e1rio.","type":"string","required":false},"last_name":{"description":"Sobrenome para o usu\u00e1rio.","type":"string","required":false},"email":{"description":"O endere\u00e7o de e-mail para o usu\u00e1rio.","type":"string","format":"email","required":false},"url":{"description":"URL do usu\u00e1rio.","type":"string","format":"uri","required":false},"description":{"description":"Descri\u00e7\u00e3o do usu\u00e1rio.","type":"string","required":false},"locale":{"description":"Localidade para o usu\u00e1rio.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","ja","ko_KR","pt_BR","th","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"O apelido para o usu\u00e1rio.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o usu\u00e1rio.","type":"string","required":false},"roles":{"description":"Fun\u00e7\u00f5es atribu\u00eddas ao usu\u00e1rio.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Senha para o usu\u00e1rio (nunca incluso).","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A data e o hor\u00e1rio que as prefer\u00eancias foram atualizadas.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio para ser verdadeiro, como usu\u00e1rios n\u00e3o suporta lixeira.","required":false},"reassign":{"type":"integer","description":"Reatribuir os posts e links do usu\u00e1rio exclu\u00eddo para este ID de usu\u00e1rio.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Um UUID fornecido pela aplica\u00e7\u00e3o para identific\u00e1-la de forma \u00fanica. Recomenda-se usar o UUID vers\u00e3o 5 com o URL ou namespace DNS.","type":"string","format":"uuid","required":false},"name":{"description":"O nome da senha da aplica\u00e7\u00e3o.","type":"string","minLength":1,"pattern":".*\\S.*","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Um UUID fornecido pela aplica\u00e7\u00e3o para identific\u00e1-la de forma \u00fanica. Recomenda-se usar o UUID vers\u00e3o 5 com o URL ou namespace DNS.","type":"string","format":"uuid","required":false},"name":{"description":"O nome da senha da aplica\u00e7\u00e3o.","type":"string","minLength":1,"pattern":".*\\S.*","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar resposta para coment\u00e1rios publicados depois de uma determinada data compat\u00edvel com a norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a coment\u00e1rios atribu\u00eddos a IDs de usu\u00e1rios espec\u00edficos. Requer autoriza\u00e7\u00e3o.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Garantir que resultados excluir\u00e3o coment\u00e1rios atribu\u00eddos a IDs de usu\u00e1rios espec\u00edficos. Requer autoriza\u00e7\u00e3o.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Limitar resultado para e-mails de autores em especifico. Requer autoriza\u00e7\u00e3o.","format":"email","type":"string","required":false},"before":{"description":"Limitar resposta para coment\u00e1rios publicados antes de uma determinada data compat\u00edvel com a norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do coment\u00e1rio.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Limitar resultados para coment\u00e1rios cujos ascendentes t\u00eam determinados IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Garantir que o resultado exclui IDs de ascendentes espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Limitar resultados para coment\u00e1rios atribu\u00eddos para IDs espec\u00edficos de post.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Limitar resultados para coment\u00e1rios atribu\u00eddos a um status espec\u00edfico. Necessita autoriza\u00e7\u00e3o.","type":"string","required":false},"type":{"default":"comment","description":"Limitar resultados para coment\u00e1rios atribu\u00eddos a um tipo espec\u00edfico. Necessita autoriza\u00e7\u00e3o.","type":"string","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"author":{"description":"O ID do usu\u00e1rio do objeto, se o autor for um usu\u00e1rio.","type":"integer","required":false},"author_email":{"description":"Endere\u00e7o e-mail para o autor do coment\u00e1rio.","type":"string","format":"email","required":false},"author_ip":{"description":"Endere\u00e7o IP para o autor do coment\u00e1rio.","type":"string","format":"ip","required":false},"author_name":{"description":"Nome de exibi\u00e7\u00e3o para o autor do coment\u00e1rio.","type":"string","required":false},"author_url":{"description":"URL para o autor do coment\u00e1rio.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agente de usu\u00e1rio para o autor do coment\u00e1rio.","type":"string","required":false},"content":{"description":"O conte\u00fado para o coment\u00e1rio.","type":"object","properties":{"raw":{"description":"Conte\u00fado do coment\u00e1rio, tal como est\u00e1 no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do coment\u00e1rio, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, no fuso hor\u00e1rio do site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, em GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"O ID do item ascendente ao coment\u00e1rio.","type":"integer","required":false},"post":{"default":0,"description":"O ID para o post associado ao objeto.","type":"integer","required":false},"status":{"description":"Estado do coment\u00e1rio.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para o coment\u00e1rio.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha do post ascendente ao coment\u00e1rio (se o post for protegido por senha).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para o coment\u00e1rio.","type":"integer","required":false},"author":{"description":"O ID do usu\u00e1rio do objeto, se o autor for um usu\u00e1rio.","type":"integer","required":false},"author_email":{"description":"Endere\u00e7o e-mail para o autor do coment\u00e1rio.","type":"string","format":"email","required":false},"author_ip":{"description":"Endere\u00e7o IP para o autor do coment\u00e1rio.","type":"string","format":"ip","required":false},"author_name":{"description":"Nome de exibi\u00e7\u00e3o para o autor do coment\u00e1rio.","type":"string","required":false},"author_url":{"description":"URL para o autor do coment\u00e1rio.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agente de usu\u00e1rio para o autor do coment\u00e1rio.","type":"string","required":false},"content":{"description":"O conte\u00fado para o coment\u00e1rio.","type":"object","properties":{"raw":{"description":"Conte\u00fado do coment\u00e1rio, tal como est\u00e1 no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do coment\u00e1rio, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, no fuso hor\u00e1rio do site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, em GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"O ID do item ascendente ao coment\u00e1rio.","type":"integer","required":false},"post":{"description":"O ID para o post associado ao objeto.","type":"integer","required":false},"status":{"description":"Estado do coment\u00e1rio.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para o coment\u00e1rio.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"password":{"description":"A senha do post ascendente ao coment\u00e1rio (se o post for protegido por senha).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"type":{"default":"post","description":"Limite os resultados aos itens de um tipo de objeto.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Limite os resultados a itens de um ou mais subtipos de objeto.","type":"array","items":{"enum":["post","page","event","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Nome registrado exclusivo para o bloco.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Atributos para o bloco.","type":"object","default":[],"required":false},"post_id":{"description":"ID de contexto do post.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namespace do bloco.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namespace do bloco.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nome do bloco.","type":"string","required":false},"namespace":{"description":"Namespace do bloco.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"T\u00edtulo","description":"T\u00edtulo do site.","type":"string","required":false},"description":{"title":"Descri\u00e7\u00e3o","description":"Slogan do site.","type":"string","required":false},"url":{"title":"","description":"URL do site.","type":"string","format":"uri","required":false},"email":{"title":"","description":"Este endere\u00e7o \u00e9 utilizado para administra\u00e7\u00e3o, como notifica\u00e7\u00e3o de novo usu\u00e1rio.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Uma cidade no mesmo fuso hor\u00e1rio que voc\u00ea.","type":"string","required":false},"date_format":{"title":"","description":"Um formato de data para todos os textos.","type":"string","required":false},"time_format":{"title":"","description":"Um formato de hora para todos os textos.","type":"string","required":false},"start_of_week":{"title":"","description":"N\u00famero do dia da semana em que a semana deve iniciar.","type":"integer","required":false},"language":{"title":"","description":"C\u00f3digo de localiza\u00e7\u00e3o do WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"Converter emoticons como :-) e :-P em gr\u00e1ficos ao exib\u00ed-los.","type":"boolean","required":false},"default_category":{"title":"","description":"Categoria padr\u00e3o para post.","type":"integer","required":false},"default_post_format":{"title":"","description":"Formato de post padr\u00e3o.","type":"string","required":false},"posts_per_page":{"title":"M\u00e1ximo de posts por p\u00e1gina","description":"As p\u00e1ginas do blog mostram no m\u00e1ximo.","type":"integer","required":false},"show_on_front":{"title":"Mostrar na frente","description":"O que exibir na p\u00e1gina inicial","type":"string","required":false},"page_on_front":{"title":"P\u00e1gina frontal","description":"O ID da p\u00e1gina que deve ser exibida na p\u00e1gina inicial","type":"integer","required":false},"page_for_posts":{"title":"","description":"O ID da p\u00e1gina que deve exibir os posts mais recentes","type":"integer","required":false},"default_ping_status":{"title":"","description":"Permitir avisos de links de outros blogs (pingbacks ou trackbacks) em novos artigos.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Permitir coment\u00e1rios em novas publica\u00e7\u00f5es","description":"Permitir que pessoas enviem coment\u00e1rios em novos posts.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Logo do site.","type":"integer","required":false},"site_icon":{"title":"\u00cdcone","description":"\u00cdcone do site.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Limitar resultados a temas com um ou mais status atribu\u00eddos.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"A folha de estilos do tema. Isso identifica exclusivamente o tema.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"status":{"description":"Limita os resultados a plugins com o status especificado.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"slug do diret\u00f3rio de plugins do WordPress.org","pattern":"[\\w\\-]+","required":true},"status":{"description":"O status de ativa\u00e7\u00e3o do plugin","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"O status de ativa\u00e7\u00e3o do plugin","type":"string","enum":["inactive","active"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O ID de uma barra lateral registrada","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Widgets aninhados.","type":"array","items":{"type":["object","string"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id do tipo de widget.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"O id do tipo de widget.","type":"string","required":true},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia atual do widget.","type":"object","required":false},"form_data":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia serializados","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"O id do tipo de widget.","type":"string","required":true},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia atual do widget.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"A barra lateral de onde se deseja retornar os widgets.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o widget.","type":"string","required":false},"id_base":{"description":"O tipo do widget. Corresponde ao ID no endpoint widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"A barra lateral a que o widget pertence.","type":"string","required":true},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia do widget, se suportado.","type":"object","properties":{"encoded":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia codificados em Base64.","type":"string","context":["edit"]},"hash":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia em hash criptografado.","type":"string","context":["edit"]},"raw":{"description":"Configura\u00e7\u00f5es n\u00e3o codificadas da inst\u00e2ncia, caso tenha suporte.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Dados no formato URL-encoded do formul\u00e1rio de administra\u00e7\u00e3o do widget. Usado para atualizar um widget que n\u00e3o permite ser instanciado. Apenas escrita. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o widget.","type":"string","required":false},"id_base":{"description":"O tipo do widget. Corresponde ao ID no endpoint widget-types.","type":"string","required":false},"sidebar":{"description":"A barra lateral a que o widget pertence.","type":"string","required":false},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia do widget, se suportado.","type":"object","properties":{"encoded":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia codificados em Base64.","type":"string","context":["edit"]},"hash":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia em hash criptografado.","type":"string","context":["edit"]},"raw":{"description":"Configura\u00e7\u00f5es n\u00e3o codificadas da inst\u00e2ncia, caso tenha suporte.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Dados no formato URL-encoded do formul\u00e1rio de administra\u00e7\u00e3o do widget. Usado para atualizar um widget que n\u00e3o permite ser instanciado. Apenas escrita. ","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Se deve-se for\u00e7ar a remo\u00e7\u00e3o do widget ou mov\u00ea-lo para a barra lateral inativa.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Limitar resultados a blocos correspondentes ao termo da pesquisa.","type":"string","minLength":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","minLength":1,"required":false},"category":{"description":"Limitar resultados para aqueles que combinam com o ID de uma categoria.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Limitar resultados para aqueles que combinam com um ID de palavra-chave.","type":"integer","minimum":1,"required":false},"slug":{"description":"Limitar os resultados para aqueles que combinam com um padr\u00e3o (slug).","type":"array","required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"O URL a ser processado.","type":"string","format":"uri","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Um identificador alfanum\u00e9rico para a localiza\u00e7\u00e3o do menu.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/pt-br\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]}},"site_logo":0,"site_icon":0,"site_icon_url":"","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}]}}
