{"name":"Altair Events","description":"Altair Events","url":"https:\/\/events.altair.com","home":"https:\/\/events.altair.com\/zh-hans\/","gmt_offset":-4,"timezone_string":"America\/Detroit","namespaces":["oembed\/1.0","wpml\/v1","post-smtp\/v1","post-smtp\/v2","psd\/v1","redirection\/v1","yoast\/v1","wpml\/st\/v1","wpml\/tm\/v1","wpml\/ate\/v1","otgs\/installer\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/events.altair.com\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"\u9700\u8981\u83b7\u53d6 oEmbed \u6570\u636e\u7684\u94fe\u63a5\u3002","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"\u9700\u8981\u83b7\u53d6 oEmbed \u6570\u636e\u7684\u94fe\u63a5\u3002","type":"string","format":"uri","required":true},"format":{"description":"\u4f7f\u7528\u7684 oEmbed \u683c\u5f0f\u3002","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"\u5d4c\u5165\u7684\u5143\u7d20\u7684\u6700\u5927\u5bbd\u5ea6\uff08\u50cf\u7d20\uff09\u3002","type":"integer","default":600,"required":false},"maxheight":{"description":"\u5d4c\u5165\u7684\u5143\u7d20\u7684\u6700\u5927\u9ad8\u5ea6\uff08\u50cf\u7d20\uff09\u3002","type":"integer","required":false},"discover":{"description":"\u5bf9\u672a\u7ecf\u6279\u51c6\u7684\u63d0\u4f9b\u8005\u662f\u5426\u8fdb\u884c oEmbed \u53d1\u73b0\u8bf7\u6c42\u3002","type":"boolean","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/oembed\/1.0\/proxy"}]}},"\/wpml\/v1":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1"}]}},"\/wpml\/v1\/custom-xml-config":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/custom-xml-config"}]}},"\/wpml\/v1\/custom-xml-config\/validate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/custom-xml-config\/validate"}]}},"\/post-smtp\/v1":{"namespace":"post-smtp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"post-smtp\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/post-smtp\/v1"}]}},"\/post-smtp\/v1\/connect-app":{"namespace":"post-smtp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/post-smtp\/v1\/connect-app"}]}},"\/post-smtp\/v1\/get-logs":{"namespace":"post-smtp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/post-smtp\/v1\/get-logs"}]}},"\/post-smtp\/v1\/disconnect-site":{"namespace":"post-smtp\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/post-smtp\/v1\/disconnect-site"}]}},"\/post-smtp\/v1\/get-log":{"namespace":"post-smtp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/post-smtp\/v1\/get-log"}]}},"\/post-smtp\/v1\/resend-email":{"namespace":"post-smtp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/post-smtp\/v1\/resend-email"}]}},"\/post-smtp\/v2":{"namespace":"post-smtp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"post-smtp\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/post-smtp\/v2"}]}},"\/post-smtp\/v2\/get-logs":{"namespace":"post-smtp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/post-smtp\/v2\/get-logs"}]}},"\/post-smtp\/v2\/validate-license":{"namespace":"post-smtp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/post-smtp\/v2\/validate-license"}]}},"\/psd\/v1":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"psd\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/psd\/v1"}]}},"\/psd\/v1\/get-logs":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/psd\/v1\/get-logs"}]}},"\/psd\/v1\/get-details":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/psd\/v1\/get-details"}]}},"\/psd\/v1\/resend-email":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/psd\/v1\/resend-email"}]}},"\/psd\/v1\/email-count":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/psd\/v1\/email-count"}]}},"\/psd\/v1\/minimize-maximize-ad":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/psd\/v1\/minimize-maximize-ad"}]}},"\/psd\/v1\/get-failed-logs":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/psd\/v1\/get-failed-logs"}]}},"\/psd\/v1\/open-notification":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/psd\/v1\/open-notification"}]}},"\/psd\/v1\/remove-notification":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/psd\/v1\/remove-notification"}]}},"\/redirection\/v1":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"redirection\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1"}]}},"\/redirection\/v1\/redirect":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1\/redirect"}]}},"\/redirection\/v1\/redirect\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/redirect\/post":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"text":{"description":"Text to match","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1\/redirect\/post"}]}},"\/redirection\/v1\/bulk\/redirect\/(?P<bulk>delete|enable|disable|reset)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["source","last_count","last_access","position","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"global":{"description":"Apply bulk action globally, as per filters","type":"boolean","required":false},"items":{"description":"Array of IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/group":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true},"status":{"description":"Status of the group","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1\/group"}]}},"\/redirection\/v1\/group\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"moduleId":{"description":"Module ID","type":"integer","minimum":0,"maximum":3,"required":true},"name":{"description":"Group name","type":"string","required":true},"status":{"description":"Status of the group","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/bulk\/group\/(?P<bulk>delete|enable|disable)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["name","id",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/log":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1\/log"}]}},"\/redirection\/v1\/bulk\/log\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/404":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1\/404"}]}},"\/redirection\/v1\/bulk\/404\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"description":"Field to filter by","required":false},"orderby":{"description":"Field to order results by","type":"string","enum":["url","ip","total","count",""],"required":false},"direction":{"description":"Direction of ordered results","type":"string","default":"desc","enum":["asc","desc"],"required":false},"per_page":{"description":"Number of results per page","type":"integer","default":25,"minimum":5,"maximum":200,"required":false},"page":{"description":"Page offset","type":"integer","minimum":0,"default":0,"required":false},"items":{"description":"Comma separated list of item IDs to perform action on","type":"array","items":{"description":"Item ID","type":["string","number"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/setting":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1\/setting"}]}},"\/redirection\/v1\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Name","type":"string","required":false},"value":{"description":"Value","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1\/plugin"}]}},"\/redirection\/v1\/plugin\/delete":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1\/plugin\/delete"}]}},"\/redirection\/v1\/plugin\/test":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1\/plugin\/test"}]}},"\/redirection\/v1\/plugin\/data":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"upgrade":{"description":"Upgrade parameter","type":"string","enum":["stop","skip","retry"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1\/plugin\/data"}]}},"\/redirection\/v1\/import\/file\/(?P<group_id>\\d+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/redirection\/v1\/import\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/redirection\/v1\/import\/plugin"}]}},"\/redirection\/v1\/export\/(?P<module>1|2|3|all)\/(?P<format>csv|apache|nginx|json)":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/wincher\/authorization-url":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/wincher\/authorization-url"}]}},"\/yoast\/v1\/wincher\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true},"websiteId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/wincher\/authenticate"}]}},"\/yoast\/v1\/wincher\/keyphrases\/track":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/wincher\/keyphrases\/track"}]}},"\/yoast\/v1\/wincher\/keyphrases":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyphrases":{"required":false},"permalink":{"required":false},"startAt":{"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/wincher\/keyphrases"}]}},"\/yoast\/v1\/wincher\/keyphrases\/untrack":{"namespace":"yoast\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/wincher\/keyphrases\/untrack"}]}},"\/yoast\/v1\/wincher\/account\/limit":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/wincher\/account\/limit"}]}},"\/yoast\/v1\/wincher\/account\/upgrade-campaign":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/wincher\/account\/upgrade-campaign"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/yoast\/v1\/workouts"}]}},"\/wpml\/st\/v1":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/st\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/st\/v1"}]}},"\/wpml\/st\/v1\/strings\/settings":{"namespace":"wpml\/st\/v1","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"autoregisterType":{"type":"integer","default":0,"required":false},"shouldRegisterBackendStrings":{"type":"integer","default":0,"required":false},"setNoticeThatCachePluginCanBlockAutoregisterAsDismissed":{"type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/st\/v1\/strings\/settings"}]}},"\/wpml\/st\/v1\/strings\/itemscount":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/st\/v1\/strings\/itemscount"}]}},"\/wpml\/st\/v1\/strings":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/st\/v1\/strings"}]}},"\/wpml\/st\/v1\/strings\/filters":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/st\/v1\/strings\/filters"}]}},"\/wpml\/st\/v1\/string-packages":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/st\/v1\/string-packages"}]}},"\/wpml\/st\/v1\/strings\/processstringsqueue":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/st\/v1\/strings\/processstringsqueue"}]}},"\/wpml\/tm\/v1":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/tm\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/store":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_job_id":{"type":"string","required":true},"ate_job_data":{"type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/store"}]}},"\/wpml\/tm\/v1\/xliff\/fetch\/(?P<jobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/ams\/register_manager":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/register_manager"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/translators":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/translators"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/managers":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/managers"}]}},"\/wpml\/tm\/v1\/ams\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/status"}]}},"\/wpml\/tm\/v1\/ams\/console":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/console"}]}},"\/wpml\/tm\/v1\/ams\/engines":{"namespace":"wpml\/tm\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ams\/engines"}]}},"\/wpml\/tm\/v1\/ate\/jobs":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ate\/jobs"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/jobs":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"local_job_ids":{"type":"string","required":false},"scope":{"type":"string","required":false},"id":{"type":"integer","required":false},"title":{"type":"string","required":false},"source_language":{"type":"string","required":false},"target_language":{"type":"string","required":false},"status":{"type":"string","required":false},"needs_update":{"type":"string","required":false},"limit":{"type":"integer","required":false},"offset":{"type":"integer","required":false},"sorting":{"required":false},"translated_by":{"type":"string","required":false},"sent_from":{"type":"string","required":false},"sent_to":{"type":"string","required":false},"deadline_from":{"type":"string","required":false},"deadline_to":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/jobs"}]}},"\/wpml\/tm\/v1\/jobs\/assign":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"jobId":{"required":true},"type":{"required":false},"translatorId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/jobs\/assign"}]}},"\/wpml\/tm\/v1\/jobs\/cancel":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/jobs\/cancel"}]}},"\/wpml\/tm\/v1\/tp\/xliff\/download\/(?P<job_id>\\d+)\/(?P<job_type>\\w+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"job_id":{"required":true},"job_type":{"required":true},"json":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/tp\/apply-translations":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/tp\/apply-translations"}]}},"\/wpml\/tm\/v1\/tp\/batches\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batchId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/tp\/batches\/sync"}]}},"\/wpml\/tm\/v1\/tp\/batches\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/tp\/batches\/status"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"lockKey":{"type":"string","required":false},"ateToken":{"type":"string","required":false},"page":{"type":"int","required":false},"numberOfPages":{"type":"int","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/sync"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/download":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/download"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/retry":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/retry"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/receive\/(?P<wpmlJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpmlJobId":{"type":"int","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)\/fix":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wpml\/ate\/v1":{"namespace":"wpml\/ate\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/ate\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/ate\/v1"}]}},"\/wpml\/ate\/v1\/ate\/proxy":{"namespace":"wpml\/ate\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/ate\/v1\/ate\/proxy"}]}},"\/wpml\/st\/v1\/import_mo_strings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"type":"array","required":false},"themes":{"type":"array","required":false},"other":{"type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/st\/v1\/import_mo_strings"}]}},"\/wpml\/st\/v1\/pre_generate_mo_files":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/st\/v1\/pre_generate_mo_files"}]}},"\/wpml\/st\/v1\/settings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"group":{"required":true},"key":{"required":true},"data":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/st\/v1\/settings"}]}},"\/wpml\/v1\/updates":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/updates"}]}},"\/wpml\/v1\/item-sections\/populated":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/item-sections\/populated"}]}},"\/wpml\/v1\/posts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/posts"}]}},"\/wpml\/v1\/posts\/count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/posts\/count"}]}},"\/wpml\/v1\/send-to-translation\/validate-translation-options":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/send-to-translation\/validate-translation-options"}]}},"\/wpml\/v1\/send-to-translation\/default-batch-name":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/send-to-translation\/default-batch-name"}]}},"\/wpml\/v1\/send-to-translation\/validate-batch-name":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/send-to-translation\/validate-batch-name"}]}},"\/wpml\/v1\/set-review-translation-option":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/set-review-translation-option"}]}},"\/wpml\/v1\/posts\/hierarchical":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/posts\/hierarchical"}]}},"\/wpml\/v1\/posts\/taxonomies":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/posts\/taxonomies"}]}},"\/wpml\/v1\/posts\/terms":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/posts\/terms"}]}},"\/wpml\/v1\/translate-everything\/enable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/translate-everything\/enable"}]}},"\/wpml\/v1\/translate-everything\/disable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/translate-everything\/disable"}]}},"\/wpml\/v1\/getuntranslatedtypescount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/getuntranslatedtypescount"}]}},"\/wpml\/v1\/save-translator-note":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/save-translator-note"}]}},"\/wpml\/v1\/credits":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/credits"}]}},"\/wpml\/v1\/translation-proxy\/commit-batch":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/translation-proxy\/commit-batch"}]}},"\/wpml\/v1\/tranlsation-proxy\/getlastpickedup":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/tranlsation-proxy\/getlastpickedup"}]}},"\/wpml\/v1\/translation-proxy\/getRemoteJobsCount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/translation-proxy\/getRemoteJobsCount"}]}},"\/wpml\/v1\/gettranslationstatus":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/gettranslationstatus"}]}},"\/wpml\/v1\/getlocaltranslatorbyid":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/getlocaltranslatorbyid"}]}},"\/wpml\/v1\/reloadremotetranslationservice":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/reloadremotetranslationservice"}]}},"\/wpml\/v1\/gettranslationeditortype":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/gettranslationeditortype"}]}},"\/wpml\/v1\/translate-existing-content":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/translate-existing-content"}]}},"\/wpml\/v1\/get-needs-update-count-created-in-cte":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/get-needs-update-count-created-in-cte"}]}},"\/wpml\/v1\/get-engines":{"namespace":"wpml\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/get-engines"}]}},"\/wpml\/v1\/save-automatic-translation-settings":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/save-automatic-translation-settings"}]}},"\/wpml\/v1\/getlocaltranslators":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/getlocaltranslators"}]}},"\/wpml\/v1\/account-balances":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/account-balances"}]}},"\/wpml\/v1\/glossary-count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/glossary-count"}]}},"\/wpml\/v1\/enable-ate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/enable-ate"}]}},"\/wpml\/v1\/get-dismissed-notices":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/get-dismissed-notices"}]}},"\/wpml\/v1\/dismiss-notice":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/dismiss-notice"}]}},"\/wpml\/v1\/dismiss-notice-per-user":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wpml\/v1\/dismiss-notice-per-user"}]}},"\/otgs\/installer\/v1":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"otgs\/installer\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/otgs\/installer\/v1"}]}},"\/otgs\/installer\/v1\/push\/fetch-subscription":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/otgs\/installer\/v1\/push\/fetch-subscription"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u57fa\u4e8e\u591a\u4e2a\u5206\u7c7b\u6cd5\u95f4\u7684\u5173\u7cfb\u9650\u5236\u7ed3\u679c\u96c6\u3002","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 categories \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u4e86\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"\u662f\u5426\u5728\u9650\u5236\u7ed3\u679c\u96c6\u7684\u9879\u76ee\u4e2d\u5305\u542b\u5b50\u9879\u76ee\u3002","type":"boolean","default":false},"operator":{"description":"\u9879\u76ee\u662f\u5426\u5fc5\u987b\u5206\u914d\u6240\u6709\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u672f\u8bed\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 categories \u5206\u7c7b\u6cd5\u4e2d\u672a\u6307\u5b9a\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"\u662f\u5426\u5728\u9650\u5236\u7ed3\u679c\u96c6\u7684\u9879\u76ee\u4e2d\u5305\u542b\u5b50\u9879\u76ee\u3002","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 tags \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u4e86\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u9879\u76ee\u662f\u5426\u5fc5\u987b\u5206\u914d\u6240\u6709\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u672f\u8bed\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 tags \u5206\u7c7b\u6cd5\u4e2d\u672a\u6307\u5b9a\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u7f6e\u9876\u9879\u76ee\u3002","type":"boolean","required":false},"format":{"description":"Limit result set to items assigned one or more given formats.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6587\u7ae0\u7684\u5f62\u5f0f\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u6587\u7ae0\u662f\u5426\u4e3a\u7f6e\u9876\u3002","type":"boolean","required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"categories":{"description":"\u5728 category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u5728 post_tag \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u8986\u76d6\u9ed8\u8ba4\u6458\u8981\u957f\u5ea6\u3002","type":"integer","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6587\u7ae0\u7684\u5f62\u5f0f\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u6587\u7ae0\u662f\u5426\u4e3a\u7f6e\u9876\u3002","type":"boolean","required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"categories":{"description":"\u5728 category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u5728 post_tag \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"format":{"description":"\u6587\u7ae0\u7684\u5f62\u5f0f\u3002","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"\u6587\u7ae0\u662f\u5426\u4e3a\u7f6e\u9876\u3002","type":"boolean","required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"categories":{"description":"\u5728 category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"\u5728 post_tag \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u7279\u5b9a menu_order \u7684\u6587\u7ae0\u3002","type":"integer","required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u7279\u5b9a\u7236 ID \u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u9664\u7279\u5b9a\u7236 ID \u4e4b\u5916\u7684\u6240\u6709\u9879\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"parent":{"description":"\u6587\u7ae0\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u6587\u7ae0\u4e0e\u5176\u4ed6\u6587\u7ae0\u7684\u987a\u5e8f\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u8986\u76d6\u9ed8\u8ba4\u6458\u8981\u957f\u5ea6\u3002","type":"integer","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"parent":{"description":"\u6587\u7ae0\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u6587\u7ae0\u4e0e\u5176\u4ed6\u6587\u7ae0\u7684\u987a\u5e8f\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u6587\u7ae0\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"\u6587\u7ae0\u4e0e\u5176\u4ed6\u6587\u7ae0\u7684\u987a\u5e8f\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a\u7ed9\u7279\u5b9a\u4f5c\u8005\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u7279\u5b9a\u7236 ID \u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u9664\u7279\u5b9a\u7236 ID \u4e4b\u5916\u7684\u6240\u6709\u9879\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u67d0\u4e00\u5a92\u4f53\u7c7b\u578b\u7684\u9644\u4ef6\u3002","type":"string","enum":["image","video","text","application","audio"],"required":false},"mime_type":{"default":null,"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u67d0\u4e00 MIME \u7c7b\u578b\u7684\u9644\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"alt_text":{"description":"\u5728\u9644\u4ef6\u672a\u80fd\u663e\u793a\u65f6\u663e\u793a\u7684\u66ff\u6362\u6587\u672c\u3002","type":"string","required":false},"caption":{"description":"\u9644\u4ef6\u8bf4\u660e\u6587\u5b57\u3002","type":"object","properties":{"raw":{"description":"\u9644\u4ef6\u7684\u8bf4\u660e\u6587\u5b57\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7684 HTML \u8bf4\u660e\u6587\u5b57\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u9644\u4ef6\u7684\u63cf\u8ff0\u3002","type":"object","properties":{"raw":{"description":"\u9644\u4ef6\u7684\u63cf\u8ff0\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7684 HTML \u63cf\u8ff0\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"\u9644\u4ef6\u6240\u5c5e\u6587\u7ae0\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"\u6587\u7ae0\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"comment_status":{"description":"\u6587\u7ae0\u662f\u5426\u5f00\u653e\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"\u6587\u7ae0\u662f\u5426\u63a5\u53d7 Ping\u3002","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"alt_text":{"description":"\u5728\u9644\u4ef6\u672a\u80fd\u663e\u793a\u65f6\u663e\u793a\u7684\u66ff\u6362\u6587\u672c\u3002","type":"string","required":false},"caption":{"description":"\u9644\u4ef6\u8bf4\u660e\u6587\u5b57\u3002","type":"object","properties":{"raw":{"description":"\u9644\u4ef6\u7684\u8bf4\u660e\u6587\u5b57\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7684 HTML \u8bf4\u660e\u6587\u5b57\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u9644\u4ef6\u7684\u63cf\u8ff0\u3002","type":"object","properties":{"raw":{"description":"\u9644\u4ef6\u7684\u63cf\u8ff0\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u9644\u4ef6\u7684 HTML \u63cf\u8ff0\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"\u9644\u4ef6\u6240\u5c5e\u6587\u7ae0\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u9644\u4ef6\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"\u5df2\u7ecf\u7f16\u8f91\u7684\u56fe\u7247\u6587\u4ef6 \u7684 URL\u3002","type":"string","format":"uri","required":true},"modifiers":{"description":"\u56fe\u7247\u7f16\u8f91\u6570\u7ec4\u3002","type":"array","minItems":1,"items":{"description":"\u56fe\u7247\u7f16\u8f91","type":"object","required":["type","args"],"oneOf":[{"title":"\u65cb\u8f6c","properties":{"type":{"description":"\u65cb\u8f6c\u7c7b\u578b\u3002","type":"string","enum":["rotate"]},"args":{"description":"\u65cb\u8f6c\u53c2\u6570\u3002","type":"object","required":["angle"],"properties":{"angle":{"description":"\u987a\u65f6\u9488\u65cb\u8f6c\u7684\u89d2\u5ea6\u3002","type":"number"}}}}},{"title":"\u88c1\u526a","properties":{"type":{"description":"\u88c1\u526a\u65b9\u5f0f\u3002","type":"string","enum":["crop"]},"args":{"description":"\u88c1\u526a\u53c2\u6570\u3002","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"\u4ece\u5de6\u8fb9\u5f00\u59cb\u88c1\u526a\u7684\u6c34\u5e73\u4f4d\u7f6e\u4ee5\u5360\u7528\u56fe\u7247\u5bbd\u5ea6\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002","type":"number"},"top":{"description":"\u4ece\u9876\u90e8\u5f00\u59cb\u88c1\u526a\u7684\u5782\u76f4\u4f4d\u7f6e\u4ee5\u5360\u7528\u56fe\u7247\u9ad8\u5ea6\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002","type":"number"},"width":{"description":"\u88c1\u526a\u5bbd\u5ea6\u4ee5\u5360\u7528\u56fe\u7247\u5bbd\u5ea6\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002","type":"number"},"height":{"description":"\u88c1\u526a\u7684\u9ad8\u5ea6\u4ee5\u5360\u7528\u56fe\u7247\u9ad8\u5ea6\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002","type":"number"}}}}}]},"required":false},"rotation":{"description":"\u987a\u65f6\u9488\u65cb\u8f6c\u7684\u89d2\u5ea6\u91cf\u3002\u5df2\u5f03\u7528\uff1a\u8bf7\u6539\u4e3a\u4f7f\u7528 `modifiers` \u53c2\u6570\u3002","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"\u4ece X \u8f74\u5f00\u59cb\u88c1\u526a\u7684\u4f4d\u7f6e\u4ee5\u5360\u7528\u56fe\u7247\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002\u5df2\u5f03\u7528\u3002\u4f7f\u7528`modifiers`\u4ee3\u66ff\u3002","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"\u4ece Y \u8f74\u5f00\u59cb\u88c1\u526a\u7684\u4f4d\u7f6e\u4ee5\u5360\u7528\u56fe\u7247\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002\u5df2\u5f03\u7528\u3002\u4f7f\u7528`modifiers`\u4ee3\u66ff\u3002","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"\u88c1\u526a\u5bbd\u5ea6\u4ee5\u56fe\u7247\u6240\u5360\u7528\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002\u5df2\u5f03\u7528\u3002\u4f7f\u7528`modifiers`\u4ee3\u66ff\u3002","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"\u88c1\u526a\u9ad8\u5ea6\u4ee5\u56fe\u7247\u6240\u7ad9\u7528\u7684\u767e\u5206\u6bd4\u8ba1\u7b97\u3002\u5df2\u5f03\u7528\u3002\u4f7f\u7528`modifiers`\u4ee3\u66ff\u3002","type":"number","minimum":0,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u57fa\u4e8e\u591a\u4e2a\u5206\u7c7b\u6cd5\u95f4\u7684\u5173\u7cfb\u9650\u5236\u7ed3\u679c\u96c6\u3002","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 menus \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u4e86\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u9879\u76ee\u662f\u5426\u5fc5\u987b\u5206\u914d\u6240\u6709\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u672f\u8bed\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 menus \u5206\u7c7b\u6cd5\u4e2d\u672a\u6307\u5b9a\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u7279\u5b9a menu_order \u7684\u6587\u7ae0\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\u3002","type":["string","object"],"properties":{"raw":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u5bf9\u8c61\u7684 HTML \u6807\u9898\uff0c\u8f6c\u6362\u540e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"\u539f\u59cb\u8868\u793a\u7684\u5bf9\u8c61\u7ec4\uff0c\u5982\u300cpost_type\u300d\u6216\u300ctaxonomy\u300d\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"\u5bf9\u8c61\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"parent":{"default":0,"description":"\u5bf9\u8c61\u7684\u7236\u5bf9\u8c61 ID\u3002","type":"integer","minimum":0,"required":false},"attr_title":{"description":"\u6b64\u83dc\u5355\u9879\u7684 link \u5143\u7d20\u7684 title \u5c5e\u6027\u7684\u6587\u672c\u3002","type":"string","required":false},"classes":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684\u7c7b\u540d\u79f0\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"menu_order":{"default":1,"description":"\u5bfc\u822a\u83dc\u5355\u9879\u7684 nav_menu_item \u7684 DB ID\uff08\u5982\u679c\u6709\uff09\uff0c\u5426\u5219\u4e3a 0\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u5bf9\u8c61\u521d\u59cb\u7684\u8868\u793a\u7c7b\u578b\uff0c\u5982 \u300c\u5206\u7c7b\u300d\u3001\u300c\u6587\u7ae0\u300d\u548c\u300c\u9644\u4ef6\u300d\u3002","type":"string","required":false},"object_id":{"default":0,"description":"\u6b64\u83dc\u5355\u9879\u8868\u793a\u7684\u539f\u59cb\u5bf9\u8c61\u7684\u6570\u636e\u5e93 ID\uff0c\u4f8b\u5982\u6587\u7ae0\u7684 ID \u6216\u5206\u7c7b\u7684 term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684 target \u5c5e\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u8be5\u83dc\u5355\u9879\u6307\u5411\u7684 URL\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u8be5\u83dc\u5355\u9879\u7684\u94fe\u63a5\u4e2d\u8868\u793a\u7684 XFN \u5173\u7cfb\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u6b64\u5bf9\u8c61\u5728 nav_menu \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u7684\u9879\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"title":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\u3002","type":["string","object"],"properties":{"raw":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u5bf9\u8c61\u7684 HTML \u6807\u9898\uff0c\u8f6c\u6362\u540e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"\u539f\u59cb\u8868\u793a\u7684\u5bf9\u8c61\u7ec4\uff0c\u5982\u300cpost_type\u300d\u6216\u300ctaxonomy\u300d\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"\u5bf9\u8c61\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"parent":{"description":"\u5bf9\u8c61\u7684\u7236\u5bf9\u8c61 ID\u3002","type":"integer","minimum":0,"required":false},"attr_title":{"description":"\u6b64\u83dc\u5355\u9879\u7684 link \u5143\u7d20\u7684 title \u5c5e\u6027\u7684\u6587\u672c\u3002","type":"string","required":false},"classes":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684\u7c7b\u540d\u79f0\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"menu_order":{"description":"\u5bfc\u822a\u83dc\u5355\u9879\u7684 nav_menu_item \u7684 DB ID\uff08\u5982\u679c\u6709\uff09\uff0c\u5426\u5219\u4e3a 0\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u5bf9\u8c61\u521d\u59cb\u7684\u8868\u793a\u7c7b\u578b\uff0c\u5982 \u300c\u5206\u7c7b\u300d\u3001\u300c\u6587\u7ae0\u300d\u548c\u300c\u9644\u4ef6\u300d\u3002","type":"string","required":false},"object_id":{"description":"\u6b64\u83dc\u5355\u9879\u8868\u793a\u7684\u539f\u59cb\u5bf9\u8c61\u7684\u6570\u636e\u5e93 ID\uff0c\u4f8b\u5982\u6587\u7ae0\u7684 ID \u6216\u5206\u7c7b\u7684 term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684 target \u5c5e\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u8be5\u83dc\u5355\u9879\u6307\u5411\u7684 URL\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u8be5\u83dc\u5355\u9879\u7684\u94fe\u63a5\u4e2d\u8868\u793a\u7684 XFN \u5173\u7cfb\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u6b64\u5bf9\u8c61\u5728 nav_menu \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u7684\u9879\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u5bf9\u8c61\u7684\u7236\u5bf9\u8c61 ID\u3002","type":"integer","minimum":0,"required":false},"title":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\u3002","type":["string","object"],"properties":{"raw":{"description":"\u5bf9\u8c61\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u5bf9\u8c61\u7684 HTML \u6807\u9898\uff0c\u8f6c\u6362\u540e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"\u539f\u59cb\u8868\u793a\u7684\u5bf9\u8c61\u7ec4\uff0c\u5982\u300cpost_type\u300d\u6216\u300ctaxonomy\u300d\u3002","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"\u5bf9\u8c61\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"attr_title":{"description":"\u6b64\u83dc\u5355\u9879\u7684 link \u5143\u7d20\u7684 title \u5c5e\u6027\u7684\u6587\u672c\u3002","type":"string","required":false},"classes":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684\u7c7b\u540d\u79f0\u3002","type":"array","items":{"type":"string"},"required":false},"description":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"menu_order":{"description":"\u5bfc\u822a\u83dc\u5355\u9879\u7684 nav_menu_item \u7684 DB ID\uff08\u5982\u679c\u6709\uff09\uff0c\u5426\u5219\u4e3a 0\u3002","type":"integer","minimum":1,"required":false},"object":{"description":"\u5bf9\u8c61\u521d\u59cb\u7684\u8868\u793a\u7c7b\u578b\uff0c\u5982 \u300c\u5206\u7c7b\u300d\u3001\u300c\u6587\u7ae0\u300d\u548c\u300c\u9644\u4ef6\u300d\u3002","type":"string","required":false},"object_id":{"description":"\u6b64\u83dc\u5355\u9879\u8868\u793a\u7684\u539f\u59cb\u5bf9\u8c61\u7684\u6570\u636e\u5e93 ID\uff0c\u4f8b\u5982\u6587\u7ae0\u7684 ID \u6216\u5206\u7c7b\u7684 term_id\u3002","type":"integer","minimum":0,"required":false},"target":{"description":"\u6b64\u83dc\u5355\u9879\u7684\u94fe\u63a5\u5143\u7d20\u7684 target \u5c5e\u6027\u3002","type":"string","enum":["_blank",""],"required":false},"url":{"description":"\u8be5\u83dc\u5355\u9879\u6307\u5411\u7684 URL\u3002","type":"string","format":"uri","required":false},"xfn":{"description":"\u8be5\u83dc\u5355\u9879\u7684\u94fe\u63a5\u4e2d\u8868\u793a\u7684 XFN \u5173\u7cfb\u3002","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"\u6b64\u5bf9\u8c61\u5728 nav_menu \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u7684\u9879\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"tax_relation":{"description":"\u57fa\u4e8e\u591a\u4e2a\u5206\u7c7b\u6cd5\u95f4\u7684\u5173\u7cfb\u9650\u5236\u7ed3\u679c\u96c6\u3002","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 wp_pattern_category \u5206\u7c7b\u6cd5\u4e2d\u6307\u5b9a\u4e86\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"\u9879\u76ee\u662f\u5426\u5fc5\u987b\u5206\u914d\u6240\u6709\u6216\u4efb\u4f55\u6307\u5b9a\u7684\u672f\u8bed\u3002","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5728 wp_pattern_category \u5206\u7c7b\u6cd5\u4e2d\u672a\u6307\u5b9a\u7279\u5b9a\u9879\u76ee\u7684\u9879\u76ee\u3002","type":["object","array"],"oneOf":[{"title":"\u672f\u8bed ID \u5217\u8868","description":"\u5c06\u9879\u76ee\u4e0e\u5217\u51fa\u7684 ID \u76f8\u5339\u914d\u3002","type":"array","items":{"type":"integer"}},{"title":"\u672f\u8bed ID \u5206\u7c7b\u6cd5\u67e5\u8be2\u3002","description":"\u8fdb\u884c\u4e00\u9879\u9ad8\u7ea7\u9879\u76ee\u67e5\u8be2\u3002","type":"object","properties":{"terms":{"description":"\u672f\u8bed ID\u3002","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u5728 wp_pattern_category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"\u8986\u76d6\u9ed8\u8ba4\u6458\u8981\u957f\u5ea6\u3002","type":"integer","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u5728 wp_pattern_category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"\u8be5\u7bc7\u6587\u7ae0\u7684\u6458\u8981\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6458\u8981\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6458\u8981\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"\u6458\u8981\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"_acf_changed":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wp_pattern_category":{"description":"\u5728 wp_pattern_category \u5206\u7c7b\u6cd5\u4e2d\u5206\u914d\u7ed9\u8be5\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"\u9650\u5236\u4e3a\u6307\u5b9a\u7684\u6587\u7ae0 ID\u3002","type":"integer","required":false},"area":{"description":"\u9650\u5236\u4e3a\u6307\u5b9a\u7684\u6a21\u677f\u7ec4\u4ef6\u533a\u3002","type":"string","required":false},"post_type":{"description":"\u8981\u83b7\u53d6\u6a21\u677f\u7684\u6587\u7ae0\u7c7b\u578b\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"default":"","description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"default":"publish","description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u83b7\u53d6\u56de\u9000\u6240\u7528\u7684\u6a21\u677f\u7684\u522b\u540d\uff1a","type":"string","required":true},"is_custom":{"description":"\u6307\u660e\u6a21\u677f\u662f\u81ea\u5b9a\u4e49\u7684\uff0c\u6216\u662f\u5c5e\u4e8e\u6a21\u677f\u5c42\u7ea7\u7684\u4e00\u90e8\u5206","type":"boolean","required":false},"template_prefix":{"description":"\u6240\u521b\u5efa\u6a21\u677f\u7684\u6a21\u677f\u524d\u7f00\u3002 \u8fd9\u88ab\u7528\u4e8e\u63d0\u53d6\u4e3b\u6a21\u677f\u7c7b\u578b\uff0c\u4f8b\u5982\u5728\u300ctaxonomy-books\u300d\u4e2d\u5c06\u63d0\u53d6\u300ctaxonomy\u300d\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"area":{"description":"\u6a21\u677f\u7ec4\u4ef6\u7528\u9014\uff08\u9875\u7709\u3001\u9875\u811a\u7b49\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"\u9650\u5236\u4e3a\u6307\u5b9a\u7684\u6587\u7ae0 ID\u3002","type":"integer","required":false},"area":{"description":"\u9650\u5236\u4e3a\u6307\u5b9a\u7684\u6a21\u677f\u7ec4\u4ef6\u533a\u3002","type":"string","required":false},"post_type":{"description":"\u8981\u83b7\u53d6\u6a21\u677f\u7684\u6587\u7ae0\u7c7b\u578b\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"default":"","description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"default":"publish","description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"area":{"description":"\u6a21\u677f\u7ec4\u4ef6\u7528\u9014\uff08\u9875\u7709\u3001\u9875\u811a\u7b49\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"\u83b7\u53d6\u56de\u9000\u6240\u7528\u7684\u6a21\u677f\u7684\u522b\u540d\uff1a","type":"string","required":true},"is_custom":{"description":"\u6307\u660e\u6a21\u677f\u662f\u81ea\u5b9a\u4e49\u7684\uff0c\u6216\u662f\u5c5e\u4e8e\u6a21\u677f\u5c42\u7ea7\u7684\u4e00\u90e8\u5206","type":"boolean","required":false},"template_prefix":{"description":"\u6240\u521b\u5efa\u6a21\u677f\u7684\u6a21\u677f\u524d\u7f00\u3002 \u8fd9\u88ab\u7528\u4e8e\u63d0\u53d6\u4e3b\u6a21\u677f\u7c7b\u578b\uff0c\u4f8b\u5982\u5728\u300ctaxonomy-books\u300d\u4e2d\u5c06\u63d0\u53d6\u300ctaxonomy\u300d\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"slug":{"description":"\u6807\u8bc6\u6a21\u677f\u7684\u552f\u4e00\u522b\u540d\u3002","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"\u6a21\u677f\u7684\u4e3b\u9898\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"type":{"description":"\u6a21\u677f\u7684\u7c7b\u578b\u3002","type":"string","required":false},"content":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u5185\u5bb9\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit"]},"block_version":{"description":"\u6a21\u677f\u4f7f\u7528\u7684\u5185\u5bb9\u5757\u683c\u5f0f\u7684\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"\u6a21\u677f\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u6a21\u677f\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6a21\u677f\u7684 HTML \u6807\u9898\uff0c\u5df2\u8f6c\u6362\u4ee5\u4f9b\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"\u6a21\u677f\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"status":{"description":"\u6a21\u677f\u7684\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"author":{"description":"\u6a21\u677f\u4f5c\u8005\u7684 ID\u3002","type":"integer","required":false},"area":{"description":"\u6a21\u677f\u7ec4\u4ef6\u7528\u9014\uff08\u9875\u7709\u3001\u9875\u811a\u7b49\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u5168\u5c40\u6837\u5f0f\u4fee\u8ba2\u7248\u7236\u7248\u672c\u7684 ID\u3002","type":"integer","required":false},"id":{"description":"\u5168\u5c40\u6837\u5f0f\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"\u4e3b\u9898\u6807\u8bc6\u7b26","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"\u4e3b\u9898\u6807\u8bc6\u7b26","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"\u8be5\u6a21\u677f\u7684 ID","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"\u5168\u5c40\u6837\u5f0f\u3002","type":["object"],"required":false},"settings":{"description":"\u5168\u5c40\u8bbe\u7f6e\u3002","type":["object"],"required":false},"title":{"description":"\u5168\u5c40\u6837\u5f0f\u53d8\u4f53\u7684\u6807\u9898\u3002","type":["object","string"],"properties":{"raw":{"description":"\u5168\u5c40\u6837\u5f0f\u53d8\u4f53\u7684\u6807\u9898\uff0c\u56e0\u4e3a\u5b83\u5b58\u5728\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["view","edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u5bf9\u8c61\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"\u4fee\u8ba2\u7248\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u4fee\u8ba2\u7248\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u4fee\u8ba2\u7248\u672c\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit","embed"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"\u7528\u4e8e\u6392\u7248\u8bbe\u7f6e\u7684 theme.json \u6a21\u5f0f\u7248\u672c\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"\u4ee5\u5b57\u7b26\u4e32\u5f62\u5f0f\u7f16\u7801\u7684 theme.json \u683c\u5f0f\u7684 font-family \u58f0\u660e\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"theme_json_version":{"description":"\u7528\u4e8e\u6392\u7248\u8bbe\u7f6e\u7684 theme.json \u6a21\u5f0f\u7248\u672c\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"\u4ee5\u5b57\u7b26\u4e32\u5f62\u5f0f\u7f16\u7801\u7684 theme.json \u683c\u5f0f\u7684 font-family \u58f0\u660e\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"\u5b57\u4f53\u9762\u7684\u7236\u5b57\u4f53\u7cfb\u5217\u7684 ID\u3002","type":"integer","required":true},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"id","enum":["id","include"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"\u5b57\u4f53\u9762\u7684\u7236\u5b57\u4f53\u7cfb\u5217\u7684 ID\u3002","type":"integer","required":true},"theme_json_version":{"description":"\u7528\u4e8e\u6392\u7248\u8bbe\u7f6e\u7684 theme.json \u6a21\u5f0f\u7248\u672c\u3002","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"\u5728 theme.json \u683c\u5f0f\u4e2d\u4ee5\u5b57\u7b26\u4e32\u5f62\u5f0f\u7f16\u7801\u7684 font-face \u58f0\u660e\u3002","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"\u5b57\u4f53\u9762\u7684\u7236\u5b57\u4f53\u7cfb\u5217\u7684 ID\u3002","type":"integer","required":true},"id":{"description":"\u5b57\u4f53\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":true},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"\u5b57\u4f53\u9762\u7684\u7236\u5b57\u4f53\u7cfb\u5217\u7684 ID\u3002","type":"integer","required":true},"id":{"description":"\u5b57\u4f53\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/event":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u540e\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"modified_before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u4e3a\u4e00\u4e2a\u7ed9\u5b9a\u7684\u65e5\u671f\uff08ISO 8601 \u517c\u5bb9\u683c\u5f0f\uff09\u4e4b\u524d\u4fee\u6539\u8fc7\u7684\u6587\u7ae0\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"How to interpret the search input.","type":"string","enum":["exact"],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u7279\u5b9a\u7236 ID \u7684\u9879\u76ee\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u9664\u7279\u5b9a\u7236 ID \u4e4b\u5916\u7684\u6240\u6709\u9879\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"\u9700\u8981\u641c\u7d22\u7684\u680f\u4f4d\u540d\u79f0\u7ec4\u3002","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u7279\u5b9a\u522b\u540d\u7684\u6587\u7ae0\u3002","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u6587\u7ae0\u3002","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","acf-disabled","dp-rewrite-republish","hidden","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"parent":{"description":"\u6587\u7ae0\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/event"}]}},"\/wp\/v2\/event\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"parent":{"description":"\u6587\u7ae0\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u6587\u7ae0\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/event\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"\u6587\u7ae0\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"date":{"description":"\u6587\u7ae0\u53d1\u5e03\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"\u8be5\u6587\u7ae0\u53d1\u5e03\u7684 GMT \u65e5\u671f\u3002","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"\u6587\u7ae0\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\uff0c\u5176\u7c7b\u578b\u662f\u552f\u4e00\u7684\u3002","type":"string","required":false},"status":{"description":"\u6587\u7ae0\u7684\u547d\u540d\u72b6\u6001\u3002","type":"string","enum":["publish","future","draft","pending","private","acf-disabled","hidden"],"required":false},"password":{"description":"\u7528\u6765\u4fdd\u62a4\u5185\u5bb9\u548c\u6458\u8981\u7684\u5bc6\u7801\u3002","type":"string","required":false},"title":{"description":"\u6587\u7ae0\u7684\u6807\u9898\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u6807\u9898\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u6807\u9898\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u6587\u7ae0\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u6587\u7ae0\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"\u8be5\u6587\u7ae0\u6240\u4f7f\u7528\u7684\u5185\u5bb9\u533a\u5757\u683c\u5f0f\u7248\u672c\u3002","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"\u5185\u5bb9\u662f\u5426\u53d7\u5230\u5bc6\u7801\u4fdd\u62a4\u3002","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"\u6587\u7ae0\u7684\u7279\u8272\u5a92\u4f53 ID\u3002","type":"integer","required":false},"template":{"description":"\u7528\u4e8e\u663e\u793a\u6587\u7ae0\u7684\u4e3b\u9898\u6587\u4ef6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/event\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"id":{"description":"\u81ea\u52a8\u4fdd\u5b58\u7684 ID\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"\u6587\u7ae0\u7c7b\u578b\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"\u72b6\u6001\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"\u9650\u5236\u7ed3\u679c\u4e3a\u5173\u8054\u5230\u7279\u5b9a\u6587\u7ae0\u7c7b\u578b\u7684\u5206\u7c7b\u6cd5\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"\u5206\u7c7b\u6cd5\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u9879\u76ee\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u9690\u85cf\u672a\u88ab\u6307\u5b9a\u5230\u4efb\u4f55\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"boolean","default":false,"required":false},"parent":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u7236\u9879\u76ee\u7684\u9879\u76ee\u3002","type":"integer","required":false},"post":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u522b\u540d\u7684\u5206\u7c7b\u6cd5\u9879\u76ee\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":true},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"parent":{"description":"\u7236\u672f\u8bed ID\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":false},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"parent":{"description":"\u7236\u672f\u8bed ID\u3002","type":"integer","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u9879\u76ee\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u9879\u76ee\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u9690\u85cf\u672a\u88ab\u6307\u5b9a\u5230\u4efb\u4f55\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u522b\u540d\u7684\u5206\u7c7b\u6cd5\u9879\u76ee\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":true},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":false},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u9879\u76ee\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u9879\u76ee\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u9690\u85cf\u672a\u88ab\u6307\u5b9a\u5230\u4efb\u4f55\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u522b\u540d\u7684\u5206\u7c7b\u6cd5\u9879\u76ee\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":true},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"locations":{"description":"\u5206\u914d\u7ed9\u83dc\u5355\u7684\u4f4d\u7f6e\u3002","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"\u662f\u5426\u81ea\u52a8\u6dfb\u52a0\u9876\u7ea7\u9875\u9762\u5230\u6b64\u83dc\u5355\u3002","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":false},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"locations":{"description":"\u5206\u914d\u7ed9\u83dc\u5355\u7684\u4f4d\u7f6e\u3002","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"\u662f\u5426\u81ea\u52a8\u6dfb\u52a0\u9876\u7ea7\u9875\u9762\u5230\u6b64\u83dc\u5355\u3002","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u9879\u76ee\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u9879\u76ee\u5c5e\u6027\u6392\u5e8f\u96c6\u5408\u3002","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"\u662f\u5426\u9690\u85cf\u672a\u88ab\u6307\u5b9a\u5230\u4efb\u4f55\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"boolean","default":false,"required":false},"post":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u6587\u7ae0\u7684\u9879\u76ee\u3002","type":"integer","default":null,"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u522b\u540d\u7684\u5206\u7c7b\u6cd5\u9879\u76ee\u3002","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":true},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"description":{"description":"\u9879\u76ee\u7684 HTML \u63cf\u8ff0\u3002","type":"string","required":false},"name":{"description":"\u9879\u76ee\u7684 HTML \u6807\u9898\u3002","type":"string","required":false},"slug":{"description":"\u9879\u76ee\u7c7b\u578b\u800c\u8a00\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u9879\u76ee\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u9879\u76ee\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"default":"asc","description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"\u6309\u7528\u6237\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5177\u6709\u4e00\u4e2a\u6216\u591a\u4e2a\u522b\u540d\u7684\u7528\u6237\u3002","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5339\u914d\u81f3\u5c11\u4e00\u4e2a\u89d2\u8272\u7684\u7528\u6237\uff0c\u63a5\u53d7.csv \u683c\u5f0f\u5217\u8868\u6216\u5355\u4e2a\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5339\u914d\u81f3\u5c11\u4e00\u9879\u63d0\u4f9b\u7684\u7279\u5b9a\u529f\u80fd\u7684\u7528\u6237\u3002\u63a5\u53d7 CSV \u5217\u8868\u6216\u5355\u4e2a\u529f\u80fd\u3002","type":"array","items":{"type":"string"},"required":false},"who":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u7528\u6237\u4e2d\u7684\u6240\u6709\u4f5c\u8005\u3002","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e8e\u5df2\u53d1\u5e03\u6587\u7ae0\u7684\u7528\u6237\u3002","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","event":"event"}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"\u7528\u6237\u7684\u767b\u5f55\u540d\u3002","type":"string","required":true},"name":{"description":"\u7528\u6237\u7684\u663e\u793a\u540d\u3002","type":"string","required":false},"first_name":{"description":"\u7528\u6237\u7684\u540d\u5b57\u3002","type":"string","required":false},"last_name":{"description":"\u7528\u6237\u7684\u59d3\u6c0f\u3002","type":"string","required":false},"email":{"description":"\u7528\u6237\u7684\u90ae\u7bb1\u5730\u5740\u3002","type":"string","format":"email","required":true},"url":{"description":"\u7528\u6237\u7684 URL\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u7528\u6237\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"locale":{"description":"\u7528\u6237\u7684\u5730\u533a\u8bed\u8a00\u3002","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","ja","ko_KR","pt_BR","th","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"\u7528\u6237\u7684\u6635\u79f0\u3002","type":"string","required":false},"slug":{"description":"\u7528\u6237\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"roles":{"description":"\u7528\u6237\u88ab\u8d4b\u4e88\u7684\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u7528\u6237\u7684\u5bc6\u7801\uff08\u4ece\u4e0d\u88ab\u5305\u542b\uff09\u3002","type":"string","required":true},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u65e5\u671f\u548c\u65f6\u95f4\u7684\u504f\u597d\u8bbe\u7f6e\u5df2\u66f4\u65b0\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u7528\u6237\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u7528\u6237\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"username":{"description":"\u7528\u6237\u7684\u767b\u5f55\u540d\u3002","type":"string","required":false},"name":{"description":"\u7528\u6237\u7684\u663e\u793a\u540d\u3002","type":"string","required":false},"first_name":{"description":"\u7528\u6237\u7684\u540d\u5b57\u3002","type":"string","required":false},"last_name":{"description":"\u7528\u6237\u7684\u59d3\u6c0f\u3002","type":"string","required":false},"email":{"description":"\u7528\u6237\u7684\u90ae\u7bb1\u5730\u5740\u3002","type":"string","format":"email","required":false},"url":{"description":"\u7528\u6237\u7684 URL\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u7528\u6237\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"locale":{"description":"\u7528\u6237\u7684\u5730\u533a\u8bed\u8a00\u3002","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","ja","ko_KR","pt_BR","th","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"\u7528\u6237\u7684\u6635\u79f0\u3002","type":"string","required":false},"slug":{"description":"\u7528\u6237\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"roles":{"description":"\u7528\u6237\u88ab\u8d4b\u4e88\u7684\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u7528\u6237\u7684\u5bc6\u7801\uff08\u4ece\u4e0d\u88ab\u5305\u542b\uff09\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u65e5\u671f\u548c\u65f6\u95f4\u7684\u504f\u597d\u8bbe\u7f6e\u5df2\u66f4\u65b0\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u7528\u6237\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u7528\u6237\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"reassign":{"type":"integer","description":"\u5c06\u88ab\u5220\u9664\u7528\u6237\u7684\u6587\u7ae0\u548c\u94fe\u63a5\u91cd\u65b0\u6307\u5b9a\u5230\u6b64\u7528\u6237 ID\u3002","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"\u7528\u6237\u7684\u767b\u5f55\u540d\u3002","type":"string","required":false},"name":{"description":"\u7528\u6237\u7684\u663e\u793a\u540d\u3002","type":"string","required":false},"first_name":{"description":"\u7528\u6237\u7684\u540d\u5b57\u3002","type":"string","required":false},"last_name":{"description":"\u7528\u6237\u7684\u59d3\u6c0f\u3002","type":"string","required":false},"email":{"description":"\u7528\u6237\u7684\u90ae\u7bb1\u5730\u5740\u3002","type":"string","format":"email","required":false},"url":{"description":"\u7528\u6237\u7684 URL\u3002","type":"string","format":"uri","required":false},"description":{"description":"\u7528\u6237\u7684\u63cf\u8ff0\u3002","type":"string","required":false},"locale":{"description":"\u7528\u6237\u7684\u5730\u533a\u8bed\u8a00\u3002","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","ja","ko_KR","pt_BR","th","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"\u7528\u6237\u7684\u6635\u79f0\u3002","type":"string","required":false},"slug":{"description":"\u7528\u6237\u7684\u82f1\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"roles":{"description":"\u7528\u6237\u88ab\u8d4b\u4e88\u7684\u89d2\u8272\u3002","type":"array","items":{"type":"string"},"required":false},"password":{"description":"\u7528\u6237\u7684\u5bc6\u7801\uff08\u4ece\u4e0d\u88ab\u5305\u542b\uff09\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"\u65e5\u671f\u548c\u65f6\u95f4\u7684\u504f\u597d\u8bbe\u7f6e\u5df2\u66f4\u65b0\u3002","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"\u8981\u6c42\u4e3a true\uff0c\u56e0\u4e3a\u7528\u6237\u4e0d\u80fd\u88ab\u79fb\u52a8\u5230\u56de\u6536\u7ad9\u3002","required":false},"reassign":{"type":"integer","description":"\u5c06\u88ab\u5220\u9664\u7528\u6237\u7684\u6587\u7ae0\u548c\u94fe\u63a5\u91cd\u65b0\u6307\u5b9a\u5230\u6b64\u7528\u6237 ID\u3002","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"\u7531\u5e94\u7528\u7a0b\u5e8f\u63d0\u4f9b\u7684\u7528\u4e8e\u552f\u4e00\u8bc6\u522b\u7684 UUID\u3002\u5efa\u8bae\u4f7f\u7528\u542b\u6709 URL \u6216 DNS \u547d\u540d\u7a7a\u95f4\u7684 UUID v5\u3002","type":"string","format":"uuid","required":false},"name":{"description":"\u5e94\u7528\u7a0b\u5e8f\u5bc6\u7801\u540d\u79f0\u3002","type":"string","minLength":1,"pattern":".*\\S.*","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"\u7531\u5e94\u7528\u7a0b\u5e8f\u63d0\u4f9b\u7684\u7528\u4e8e\u552f\u4e00\u8bc6\u522b\u7684 UUID\u3002\u5efa\u8bae\u4f7f\u7528\u542b\u6709 URL \u6216 DNS \u547d\u540d\u7a7a\u95f4\u7684 UUID v5\u3002","type":"string","format":"uuid","required":false},"name":{"description":"\u5e94\u7528\u7a0b\u5e8f\u5bc6\u7801\u540d\u79f0\u3002","type":"string","minLength":1,"pattern":".*\\S.*","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"after":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u540e\u53d1\u5e03\u7684\u8bc4\u8bba\u3002","type":"string","format":"date-time","required":false},"author":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7ed9\u7279\u5b9a\u7528\u6237 ID \u7684\u8bc4\u8bba\uff0c\u9700\u8981\u6388\u6743\u3002","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a\u7ed9\u7279\u5b9a\u7528\u6237 ID \u7684\u8bc4\u8bba\uff0c\u9700\u8981\u6388\u6743\u3002","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u4f5c\u8005\u7684\u90ae\u7bb1\u5730\u5740\uff0c\u9700\u8981\u6388\u6743\u3002","format":"email","type":"string","required":false},"before":{"description":"\u5c06\u56de\u5e94\u9650\u5236\u5728\u4e00\u4e2a\u7ed9\u5b9a\u7684 ISO8601 \u517c\u5bb9\u65e5\u671f\u4e4b\u524d\u53d1\u5e03\u7684\u8bc4\u8bba\u3002","type":"string","format":"date-time","required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u8bc4\u8bba\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u7236 ID \u7684\u8bc4\u8bba\u3002","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a\u7236 ID \u7684\u8bc4\u8bba\u3002","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5173\u8054\u5230\u6307\u5b9a\u6587\u7ae0 ID \u7684\u8bc4\u8bba\u3002","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u8bbe\u7f6e\u7279\u5b9a\u72b6\u6001\u7684\u8bc4\u8bba\uff0c\u9700\u8981\u6388\u6743\u3002","type":"string","required":false},"type":{"default":"comment","description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u8bbe\u7f6e\u7279\u5b9a\u7c7b\u578b\u7684\u8bc4\u8bba\uff0c\u9700\u8981\u6388\u6743\u3002","type":"string","required":false},"password":{"description":"\u8be5\u6587\u7ae0\u7684\u5bc6\u7801\uff0c\u5982\u6587\u7ae0\u53d7\u5bc6\u7801\u4fdd\u62a4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"author":{"description":"\u7528\u6237\u5bf9\u8c61\u7684 ID\uff0c\u5982\u679c\u4f5c\u8005\u662f\u7528\u6237\u3002","type":"integer","required":false},"author_email":{"description":"\u8bc4\u8bba\u8005\u7684\u90ae\u7bb1\u5730\u5740\u3002","type":"string","format":"email","required":false},"author_ip":{"description":"\u8bc4\u8bba\u8005\u7684 IP \u5730\u5740\u3002","type":"string","format":"ip","required":false},"author_name":{"description":"\u8bc4\u8bba\u8005\u7684\u663e\u793a\u540d\u3002","type":"string","required":false},"author_url":{"description":"\u8bc4\u8bba\u8005\u7684\u7f51\u5740\u3002","type":"string","format":"uri","required":false},"author_user_agent":{"description":"\u8bc4\u8bba\u8005\u7684 User-Agent\u3002","type":"string","required":false},"content":{"description":"\u8bc4\u8bba\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u8bc4\u8bba\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8bc4\u8bba\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"\u8bc4\u8bba\u53d1\u8868\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":"string","format":"date-time","required":false},"date_gmt":{"description":"\u8bc4\u8bba\u53d1\u8868\u7684 GMT \u65e5\u671f\u3002","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"\u8bc4\u8bba\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"post":{"default":0,"description":"\u5173\u8054\u6587\u7ae0\u5bf9\u8c61\u7684 ID\u3002","type":"integer","required":false},"status":{"description":"\u8bc4\u8bba\u7684\u72b6\u6001\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u8bc4\u8bba\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"\u8bc4\u8bba\u6240\u5c5e\u6587\u7ae0\u7684\u5bc6\u7801\uff08\u5982\u679c\u8be5\u6587\u7ae0\u88ab\u5bc6\u7801\u4fdd\u62a4\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"\u8bc4\u8bba\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"author":{"description":"\u7528\u6237\u5bf9\u8c61\u7684 ID\uff0c\u5982\u679c\u4f5c\u8005\u662f\u7528\u6237\u3002","type":"integer","required":false},"author_email":{"description":"\u8bc4\u8bba\u8005\u7684\u90ae\u7bb1\u5730\u5740\u3002","type":"string","format":"email","required":false},"author_ip":{"description":"\u8bc4\u8bba\u8005\u7684 IP \u5730\u5740\u3002","type":"string","format":"ip","required":false},"author_name":{"description":"\u8bc4\u8bba\u8005\u7684\u663e\u793a\u540d\u3002","type":"string","required":false},"author_url":{"description":"\u8bc4\u8bba\u8005\u7684\u7f51\u5740\u3002","type":"string","format":"uri","required":false},"author_user_agent":{"description":"\u8bc4\u8bba\u8005\u7684 User-Agent\u3002","type":"string","required":false},"content":{"description":"\u8bc4\u8bba\u7684\u5185\u5bb9\u3002","type":"object","properties":{"raw":{"description":"\u8bc4\u8bba\u7684\u5185\u5bb9\uff0c\u5b58\u653e\u4e8e\u6570\u636e\u5e93\u4e2d\u3002","type":"string","context":["edit"]},"rendered":{"description":"\u8bc4\u8bba\u7684 HTML \u5185\u5bb9\uff0c\u7ecf\u8f6c\u6362\u540e\u7528\u4e8e\u663e\u793a\u3002","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"\u8bc4\u8bba\u53d1\u8868\u7684\u65e5\u671f\uff08\u7ad9\u70b9\u65f6\u533a\uff09\u3002","type":"string","format":"date-time","required":false},"date_gmt":{"description":"\u8bc4\u8bba\u53d1\u8868\u7684 GMT \u65e5\u671f\u3002","type":"string","format":"date-time","required":false},"parent":{"description":"\u8bc4\u8bba\u7684\u7236\u7ea7 ID\u3002","type":"integer","required":false},"post":{"description":"\u5173\u8054\u6587\u7ae0\u5bf9\u8c61\u7684 ID\u3002","type":"integer","required":false},"status":{"description":"\u8bc4\u8bba\u7684\u72b6\u6001\u3002","type":"string","required":false},"meta":{"description":"\u5143\u5b57\u6bb5\u3002","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"\u8bc4\u8bba\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u662f\u5426\u7ed5\u8fc7\u56de\u6536\u7ad9\u5e76\u5f3a\u884c\u5220\u9664\u3002","required":false},"password":{"description":"\u8bc4\u8bba\u6240\u5c5e\u6587\u7ae0\u7684\u5bc6\u7801\uff08\u5982\u679c\u8be5\u6587\u7ae0\u88ab\u5bc6\u7801\u4fdd\u62a4\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"type":{"default":"post","description":"\u9650\u5236\u7ed3\u679c\u4e3a\u4e00\u79cd\u5bf9\u8c61\u7c7b\u578b\u3002","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"\u9650\u5236\u7ed3\u679c\u4e3a\u4e00\u79cd\u6216\u591a\u79cd\u5bf9\u8c61\u5b50\u7c7b\u578b\u3002","type":"array","items":{"enum":["post","page","event","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"\u786e\u4fdd\u7ed3\u679c\u96c6\u6392\u9664\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a ID\u3002","type":"array","items":{"type":"integer"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"\u6b64\u533a\u5757\u7684\u552f\u4e00\u6ce8\u518c\u540d\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"\u6b64\u533a\u5757\u7684\u5c5e\u6027\u3002","type":"object","default":[],"required":false},"post_id":{"description":"\u6587\u7ae0\u4e0a\u4e0b\u6587\u7684 ID\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"\u533a\u5757\u547d\u540d\u7a7a\u95f4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"\u533a\u5757\u547d\u540d\u7a7a\u95f4\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"\u533a\u5757\u540d\u79f0","type":"string","required":false},"namespace":{"description":"\u533a\u5757\u547d\u540d\u7a7a\u95f4\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"\u6807\u9898","description":"\u7ad9\u70b9\u6807\u9898\u3002","type":"string","required":false},"description":{"title":"\u526f\u6807\u9898","description":"\u7ad9\u70b9\u526f\u6807\u9898\u3002","type":"string","required":false},"url":{"title":"","description":"\u7ad9\u70b9 URL\u3002","type":"string","format":"uri","required":false},"email":{"title":"","description":"\u6b64\u5730\u5740\u88ab\u7528\u4f5c\u7ba1\u7406\u7528\u9014\uff0c\u5982\u65b0\u7528\u6237\u901a\u77e5\u3002","type":"string","format":"email","required":false},"timezone":{"title":"","description":"\u548c\u60a8\u5728\u540c\u4e00\u4e2a\u65f6\u533a\u7684\u57ce\u5e02\u3002","type":"string","required":false},"date_format":{"title":"","description":"\u5bf9\u6240\u6709\u65e5\u671f\u5b57\u7b26\u4e32\u9002\u7528\u7684\u65e5\u671f\u683c\u5f0f\u3002","type":"string","required":false},"time_format":{"title":"","description":"\u5bf9\u6240\u6709\u65f6\u95f4\u5b57\u7b26\u4e32\u9002\u7528\u7684\u65f6\u95f4\u683c\u5f0f\u3002","type":"string","required":false},"start_of_week":{"title":"","description":"\u4e00\u5468\u4ece\u5468\u51e0\u5f00\u59cb\u3002","type":"integer","required":false},"language":{"title":"","description":"WordPress \u5730\u533a\u8bed\u8a00\u4ee3\u7801\u3002","type":"string","required":false},"use_smilies":{"title":"","description":"\u5c06\u8868\u60c5\u7b26\u53f7\u5982:-) \u548c:-P \u8f6c\u6362\u4e3a\u56fe\u7247\u663e\u793a\u3002","type":"boolean","required":false},"default_category":{"title":"","description":"\u9ed8\u8ba4\u6587\u7ae0\u5206\u7c7b\u3002","type":"integer","required":false},"default_post_format":{"title":"","description":"\u9ed8\u8ba4\u6587\u7ae0\u5f62\u5f0f\u3002","type":"string","required":false},"posts_per_page":{"title":"\u6bcf\u9875\u6700\u591a\u6587\u7ae0\u6570","description":"\u6700\u591a\u663e\u793a\u7684\u535a\u5ba2\u9875\u9762\u6570\u91cf\u3002","type":"integer","required":false},"show_on_front":{"title":"\u5728\u524d\u9762\u663e\u793a","description":"\u9700\u8981\u5728\u9996\u9875\u4e0a\u663e\u793a\u7684\u9879\u76ee","type":"string","required":false},"page_on_front":{"title":"\u524d\u4e00\u9875","description":"\u9700\u8981\u5728\u9996\u9875\u4e0a\u663e\u793a\u7684\u9875\u9762 ID","type":"integer","required":false},"page_for_posts":{"title":"","description":"\u9700\u8981\u663e\u793a\u6700\u65b0\u6587\u7ae0\u7684\u9875\u9762 ID","type":"integer","required":false},"default_ping_status":{"title":"","description":"\u5141\u8bb8\u5176\u4ed6\u535a\u5ba2\u53d1\u9001\u94fe\u63a5\u901a\u77e5\uff08pingback \u548c trackback\uff09\u5230\u65b0\u6587\u7ae0\u3002","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"\u5141\u8bb8\u5bf9\u65b0\u6587\u7ae0\u53d1\u8868\u8bc4\u8bba","description":"\u5141\u8bb8\u4ed6\u4eba\u5728\u65b0\u6587\u7ae0\u4e0a\u53d1\u8868\u8bc4\u8bba\u3002","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"\u7ad9\u70b9 logo","type":"integer","required":false},"site_icon":{"title":"\u56fe\u6807","description":"\u7ad9\u70b9\u56fe\u6807\u3002","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u6307\u5b9a\u4e86\u4e00\u4e2a\u6216\u591a\u4e2a\u72b6\u6001\u7684\u4e3b\u9898\u3002","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"\u4e3b\u9898\u7684\u6837\u5f0f\u8868\u3002\u8fd9\u662f\u4e3b\u9898\u7684\u552f\u4e00\u6807\u8bc6\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","required":false},"status":{"description":"\u9650\u5236\u7ed3\u679c\u96c6\u4e3a\u5177\u6709\u7ed9\u5b9a\u72b6\u6001\u7684\u63d2\u4ef6\u3002","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org \u63d2\u4ef6\u76ee\u5f55\u522b\u540d\u3002","pattern":"[\\w\\-]+","required":true},"status":{"description":"\u63d2\u4ef6\u542f\u7528\u72b6\u6001\u3002","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"\u63d2\u4ef6\u542f\u7528\u72b6\u6001\u3002","type":"string","enum":["inactive","active"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u5df2\u6ce8\u518c\u7684\u8fb9\u680f ID","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"\u5d4c\u5957\u5c0f\u5de5\u5177\u3002","type":"array","items":{"type":["object","string"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7c7b\u578b ID\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7c7b\u578b ID\u3002","type":"string","required":true},"instance":{"description":"\u5c0f\u5de5\u5177\u7684\u5f53\u524d\u8bbe\u7f6e\u5b9e\u4f8b\u3002","type":"object","required":false},"form_data":{"description":"\u5e8f\u5217\u5316\u5c0f\u5de5\u5177\u8868\u5355\u6570\u636e\uff0c\u4ee5\u7f16\u7801\u4e3a\u8bbe\u7f6e\u5b9e\u4f8b\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7c7b\u578b ID\u3002","type":"string","required":true},"instance":{"description":"\u5c0f\u5de5\u5177\u7684\u5f53\u524d\u8bbe\u7f6e\u5b9e\u4f8b\u3002","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"\u8fd4\u56de\u5c0f\u5de5\u5177\u7684\u4fa7\u8fb9\u680f\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"id_base":{"description":"\u5c0f\u5de5\u5177\u7684\u7c7b\u578b\u3002\u5bf9\u5e94\u4e8e widget-types \u7aef\u70b9\u7684 ID\u3002","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"\u5c0f\u5de5\u5177\u6240\u5c5e\u7684\u4fa7\u8fb9\u680f\u3002","type":"string","required":true},"instance":{"description":"\u5c0f\u5de5\u5177\u7684\u5b9e\u4f8b\u8bbe\u7f6e\uff08\u5982\u679c\u652f\u6301\uff09\u3002","type":"object","properties":{"encoded":{"description":"\u5b9e\u4f8b\u8bbe\u7f6e\u7684 Base64 \u7f16\u7801\u8868\u793a\u3002","type":"string","context":["edit"]},"hash":{"description":"\u5b9e\u4f8b\u8bbe\u7f6e\u7684\u52a0\u5bc6\u54c8\u5e0c\u503c\u3002","type":"string","context":["edit"]},"raw":{"description":"\u672a\u7f16\u7801\u7684\u5b9e\u4f8b\u8bbe\u7f6e\uff08\u5982\u679c\u652f\u6301\uff09\u3002","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"\u6765\u81ea\u5c0f\u5de5\u5177\u7ba1\u7406\u8868\u5355\u7684 URL \u7f16\u7801\u8868\u5355\u6570\u636e\u3002\u7528\u4e8e\u66f4\u65b0\u4e0d\u652f\u6301\u5b9e\u4f8b\u7684\u5c0f\u5de5\u5177\uff08\u6307\u5199\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"\u5c0f\u5de5\u5177\u7684\u552f\u4e00\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"id_base":{"description":"\u5c0f\u5de5\u5177\u7684\u7c7b\u578b\u3002\u5bf9\u5e94\u4e8e widget-types \u7aef\u70b9\u7684 ID\u3002","type":"string","required":false},"sidebar":{"description":"\u5c0f\u5de5\u5177\u6240\u5c5e\u7684\u4fa7\u8fb9\u680f\u3002","type":"string","required":false},"instance":{"description":"\u5c0f\u5de5\u5177\u7684\u5b9e\u4f8b\u8bbe\u7f6e\uff08\u5982\u679c\u652f\u6301\uff09\u3002","type":"object","properties":{"encoded":{"description":"\u5b9e\u4f8b\u8bbe\u7f6e\u7684 Base64 \u7f16\u7801\u8868\u793a\u3002","type":"string","context":["edit"]},"hash":{"description":"\u5b9e\u4f8b\u8bbe\u7f6e\u7684\u52a0\u5bc6\u54c8\u5e0c\u503c\u3002","type":"string","context":["edit"]},"raw":{"description":"\u672a\u7f16\u7801\u7684\u5b9e\u4f8b\u8bbe\u7f6e\uff08\u5982\u679c\u652f\u6301\uff09\u3002","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"\u6765\u81ea\u5c0f\u5de5\u5177\u7ba1\u7406\u8868\u5355\u7684 URL \u7f16\u7801\u8868\u5355\u6570\u636e\u3002\u7528\u4e8e\u66f4\u65b0\u4e0d\u652f\u6301\u5b9e\u4f8b\u7684\u5c0f\u5de5\u5177\uff08\u6307\u5199\uff09\u3002","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"\u5f3a\u884c\u79fb\u9664\u5c0f\u5de5\u5177\uff0c\u8d27\u5c06\u5176\u79fb\u52a8\u5230\u672a\u542f\u7528\u7684\u5c0f\u5de5\u5177\u4fa7\u8fb9\u680f\u3002","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"\u5c06\u7ed3\u679c\u96c6\u9650\u5236\u4e3a\u5339\u914d\u641c\u7d22\u8bcd\u7684\u533a\u5757\u3002","type":"string","minLength":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u5339\u914d\u5b57\u7b26\u4e32\u7684\u3002","type":"string","minLength":1,"required":false},"category":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u4e0e\u5206\u7c7b ID \u5339\u914d\u7684\u7ed3\u679c\u3002","type":"integer","minimum":1,"required":false},"keyword":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u4e0e\u5173\u952e\u5b57 ID \u5339\u914d\u7684\u7ed3\u679c\u3002","type":"integer","minimum":1,"required":false},"slug":{"description":"\u5c06\u7ed3\u679c\u9650\u5236\u4e3a\u4e0e\u6837\u677f\uff08\u522b\u540d\uff09\u5339\u914d\u7684\u7ed3\u679c\u3002","type":"array","required":false},"offset":{"description":"\u5c06\u7ed3\u679c\u96c6\u79fb\u4f4d\u7279\u5b9a\u6570\u91cf\u3002","type":"integer","required":false},"order":{"description":"\u8bbe\u7f6e\u6392\u5e8f\u5b57\u6bb5\u5347\u5e8f\u6216\u964d\u5e8f\u3002","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u6309\u6587\u7ae0\u5c5e\u6027\u5bf9\u96c6\u5408\u8fdb\u884c\u6392\u5e8f\u3002","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"\u8981\u5904\u7406\u7684 URL\u3002","type":"string","format":"uri","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"\u83dc\u5355\u4f4d\u7f6e\u7684\u5b57\u6bcd\u6570\u5b57\u6807\u8bc6\u7b26\u3002","type":"string","required":false},"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"\u96c6\u5408\u7684\u5f53\u524d\u9875\u3002","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"\u7ed3\u679c\u96c6\u5305\u542b\u7684\u6700\u5927\u9879\u76ee\u6570\u91cf\u3002","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/events.altair.com\/zh-hans\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u8bf7\u6c42\u63d0\u51fa\u7684\u8303\u56f4\uff0c\u7528\u4e8e\u51b3\u5b9a\u56de\u5e94\u5305\u542b\u7684\u5b57\u6bb5\u3002","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["zh-hans","zh-hant","en","fr","de","it","ja","ko","pt-br","es","th","vi"],"required":false}}}]}},"site_logo":0,"site_icon":0,"site_icon_url":"","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}]}}
